Suspension Tech Have a question about modifying your suspension? Ask it here.
Loose shocks?
Old Jan 1, 2007 | 11:08 AM
Scuba65's Avatar
Scuba65 is an unknown quantity at this point
Default Loose shocks?
The guy I bought my 96 Blazer LT from mentioned he had replaced the shocks within the past year. He did all of his maintenance work himself. Seemed pretty knowledgable about everything.
I've got this weird "clucking" or "thunking" underneath when I back out of the driveway...(it puts a little "twist" on the frame) It'll do it as I back out, and then right as I start moving forward. It's AWD, with NP3 code. I can also get it to make that sound when I hit the gas hard from a stoplight, bringing the front end up a bit, and then I let off, and as the body settles back down, I may hear a "thunk" or two.
Any ideas? Thanks!
Old Jan 1, 2007 | 12:28 PM
hillbillyinOhio's Avatar
Default RE: Loose shocks?
BALL JOINTS
Old Jan 1, 2007 | 01:32 PM
It is possible that it is ball joints, but I have also replaced the shocks on my Bravada and I had to go back in and re-tighten the shock bolts after a bit. Seems that my replacement shocks didn't have the exact same length bushing as the old ones so I had to cinch things down a bit more to get it all nice and snug. In my case, it was the upper shock bolts that were tight, but not tight enough to draw the support in and really clamp down on the bushing in the top of the shock. Give that a try before moving on to the ball joints as it may be as simple as tightening down some bolts.
Good luck and let us know if you have any more questions.
Old Jan 1, 2007 | 03:22 PM
MNHawk's Avatar
MNHawk is an unknown quantity at this point
Might want to look over your sway bar links also.
bigdaddykane93
14
May 8, 2014 08:54 AM
ussexplorer
Apr 11, 2010 06:53 PM
mike0912
Jan 27, 2010 11:51 AM
jagblazer01
Apr 16, 2009 03:54 PM
tammikm
Oct 6, 2005 09:59 AM
