Suspension Tech Have a question about modifying your suspension? Ask it here.
low cost lift - need advice here
Old Jun 29, 2006 | 10:10 AM
boomtruck97's Avatar
boomtruck97 is an unknown quantity at this point
Default low cost lift - need advice here
i was at autozone and found some 2" lift kits on the shelf. they are made as basically a spacer that is installed to gain a little room. they were cheap though. the front set was about $25 and the rear was around $35. the fronts seamed to be 2 sets of rods that had holes drilled in them, they would simply bolt in place. then the back was a bunch of U bolts and some spacer blocks. Are these usable, reliable? will they gimme that lil bit of space i want for my 17" rims?
Old Jun 29, 2006 | 02:16 PM
cherryred4x4's Avatar
cherryred4x4 is an unknown quantity at this point
Default RE: low cost lift - need advice here
First off, what kind of Blazer is it, year, 2wd or 4wd, S-10 Blazer or K5 Blazer? just need a little more information to go on, then we can give you lots of help.
Since you have 97 in your username, I'm going to assume you have a 97, if so, then you have the IFS (independent front suspension), the only way to lift the front is by cranking the torsion bars a little, or buying a complete kit with bracketry for the taller lifts. "the fronts seemed to be 2 sets of rods that had holes drilled in them" those sound like longer shackles for the front leaf springs on solid axle trucks, which will not work on an IFS truck.
Old Jun 29, 2006 | 02:45 PM
its a 93 4dr 4wd - i dont no between the s-10 and k5 but the engine was put in the s-10s as well. and it has the same dash pieces as my old s-10 did.
Old Jun 29, 2006 | 11:01 PM
ok, then its definitely an S-10 Blazer, K5 is the fullsize. What did the packaging for the front ones say? The only way to lift the front just a little without a kit is to crank the torsion bars up a little. There is a post recently in the Suspension section, or the Tires section.
01BlazerFTW
Performance & Brainstorming
Dec 28, 2019 11:46 PM
hedgepig
Oct 17, 2010 10:18 AM
INHUMAN
Lifting Tech
May 23, 2009 12:51 AM
MikeB78
Lifting Tech
Feb 18, 2009 09:35 PM
2kSnakeEater
Mar 22, 2006 05:16 PM
