Suspension Tech Have a question about modifying your suspension? Ask it here.
Ride quality & Torsion Key Lift?
Old Dec 24, 2006 | 02:22 AM
Jigg's Avatar
Jigg is an unknown quantity at this point
Default RE: Ride quality & Torsion Key Lift?
These only allow you to crank the torsion bar tighter. At stock height, with either keys, the torsion bars are cranked at the same tightness. The torsion bar tightness dictates the ride height. These keys add extra height by allowing you to crank past the normal range, overcranking if you will. The tighter you crank, the stiffer the ride.
Old Dec 25, 2006 | 12:04 AM
Dabber's Avatar
Dabber is an unknown quantity at this point
K sounds good to me
Old Jan 16, 2008 | 06:43 PM
tkebillybob's Avatar
tkebillybob is an unknown quantity at this point
FYI -- I cranked the torsion bars all the way up with offroad competition shocks. Rides like frickin' tank -- have gone through six wheel bearings, four ball joints and both cv axles. Then again she's seen more mud than the South has tobacca. I'm a put the keys in, longer control arms and add a leafs. I agree it's a truck, not a caddy!
Old Feb 22, 2009 | 04:51 PM
dober's Avatar
dober is an unknown quantity at this point
I have a question? I have a 2001 blazer LT. I bought a 3in block lift for the rear and 3in tor-bar keys. Now i keep hearing the problems from cranking the t-bar. Now my question is as far as daily driving will anything be affected or do problems mainly occur due to off-roading?
Old Feb 22, 2009 | 06:08 PM
DO NOT attempt to achieve a 3" suspension lift what so ever. Anything even approaching 2" will cause increased wear on the ball joints and the CV shafts regardless of offroad play.
Old Feb 22, 2009 | 08:03 PM
Bigringtravis's Avatar
Bigringtravis is on a distinguished road
Swartkk is right and furthmore, it leaves the front suspension to "top out" a lot. I've also read on a few other forums that the undue stress of severe lifts to these Blazers can cause frame failure just in front of the cab - Between the first body/cab mount and the upper/lower control arms... and, that's a bad day for anyone!
Old Feb 22, 2009 | 08:22 PM
Cavalier z24's Avatar
Cavalier z24 is on a distinguished road
Yeah that would be a bad idea going to 3" in front lol that's just stupidity No offense
Old Feb 22, 2009 | 08:43 PM
dober's Avatar
Thats why im asking? I want too put a set of 31 10.5 bfg all-terrain ko's and a set procomp rockcrawler wheels 15x10. I heard that this is possible? I need some opinions here guys.
Rick Calero
Aug 6, 2014 01:07 AM
mike7466
Suspension Tech
Apr 5, 2010 07:46 PM
bigkeith11
Jan 3, 2010 03:32 AM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
zachwagner
Suspension Tech
Dec 11, 2006 08:01 PM
