Suspension Tech Have a question about modifying your suspension? Ask it here.
Rough country lift kit help
Old Mar 25, 2008 | 10:16 PM
ShawnGMC's Avatar
ShawnGMC is an unknown quantity at this point
Default Rough country lift kit help
I have a 2002 gmc jimmy 4x4 and already have a 2" body lift on it, and i was looking at the rough country lift kit and was wondering if i add all the suspension stuff EXCEPT the torrison keys and crank the stock ones, will i get somewhat a stock ride without alot of worry of front end parts?
Old Mar 25, 2008 | 11:10 PM
navyblue_sk8er's Avatar
navyblue_sk8er is an unknown quantity at this point
Default RE: Rough country lift kit help
If you go 2" with stock keys its the same as going 2" with the new keys. All that matters is that you are cranking2" and your going to get decreased life of front end parts.
Old Mar 26, 2008 | 01:54 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
it will ride rough regardless. Either way, you are still cranking the t-bars..
BackwoodsBogger14
Lifting Tech
Sep 16, 2014 09:39 PM
ABASTA4
Feb 1, 2012 07:57 PM
matt92
Suspension Tech
Oct 13, 2010 02:51 PM
burningsun
15
Jun 2, 2009 06:00 PM
jessebasiuk
Oct 4, 2008 08:39 AM
