Suspension Tech Have a question about modifying your suspension? Ask it here.
Tire interference
Old Aug 16, 2005 | 12:52 AM
Lip's Avatar
Lip
Lip is an unknown quantity at this point
Default Tire interference
I just bought a 95 S10 Blazer 4x4 4 door. I have some 31 x 10.5/15 BFG A/T's that I want to put on it. It looks like the front tires will rub the back of the fender in the turns just a bit (a bit too much). What's the easiest/cheapest way to eliminate this contact? Lift the front a bit? If so, what's the easiest way to accomplish that?
Thanks for your help,
Ed
Old Sep 6, 2005 | 02:28 PM
webbyj883's Avatar
webbyj883 is an unknown quantity at this point
Default RE: Tire interference
you can probably tighten on your torsion bars a little to raise your front end. It can bring it up about 1 1/2 inches, but it will change your ride to make it a lot stiffer. You would also want to bring up your rear end as well and there are a few options with that. . . you can guy shackles to offset the springs or blocks. . . blocks are the better way to go i think.
tjmicsak
Jul 9, 2011 10:57 AM
mykeboy01
Jul 22, 2010 10:16 PM
95BlackBetty
Jul 20, 2008 07:07 AM
skybum02
Apr 15, 2008 01:33 AM
MVPalmer271
Jan 8, 2008 12:33 PM
