Camaro Wheels 2002 Blazer 4x4
I turned down the front, slightly, for a positive rake. Like a 1/2", just so the butt doesn't appear to sag.
A dremel might work but it might be too small to take off all this material. More important are tools to measure to make sure you don't take off too much and/or offset the hole.
I used a 1/4" die grinder with a carbide burr to cut and a telescoping gauge and micrometer to measure. I worked my way around the hub center, cutting and taking measurements along each segment, to make sure I stayed centered and not take off too much. I then fit each wheel to the hub and carefully took off the high spots.
Driveway is uneven in the pic, raises the rear end a bit as the drivers side wheel sits in a little dip
That is a good question. The computer would probably need programming to accept the sensor data,if that is possible. Wiring would need to be run to all four corners for the sensor pick-ups too. I wonder if Camaro wiring could be adapted to the 2nd gen ECM.
seriosbrad
May 8, 2013 07:12 PM
04SSBlazer
Mar 25, 2012 02:52 PM
