cragar backspacing
Old Nov 21, 2013 | 05:36 PM
01blazer16's Avatar
01blazer16 is on a distinguished road
Default cragar backspacing
Will the 8 in cragar backspacing push my tires out more than stock 2wd rims? I know they will be sticking out with the 31s more than stock
Old Nov 21, 2013 | 06:46 PM
rexmburns's Avatar
Super Moderator
I think you may be confused on the back spacing can you post a link to the rims you are talking about please?
Old Nov 21, 2013 | 07:14 PM
01blazer16's Avatar
They have 4in backspacing but will they push my tires out more?
will the 4in backspacing rub caliper they are 15x8 and im gonna run 31s with them??
Old Nov 22, 2013 | 10:44 AM
Jamaroon's Avatar
stock 2wd backspacing is 4.5"?
So comparing backspacing 4.5" --> 4" means the wheel will stick out .5" further due to backspacing
The wheel is also 1" wider so you have to add that in as well to make it 1.5" further out than stock wheels.
Or maybe this way might be clearer
7" wheel - 4.5" BS => outside of wheel is 2.5" from mounting surface
8" wheel - 4" BS => outside of wheel is 4" from mounting surface
4-2.5 = 1.5" further out
Old Nov 22, 2013 | 01:06 PM
01blazer16's Avatar
Ok but will these rims rub caliper?
Old Nov 22, 2013 | 01:48 PM
Jamaroon's Avatar
no.
you're going further away from the caliper and keeping the same diameter, there's no reason they would rub the caliper.
appstateblazer
Tires and Wheels
Jan 12, 2010 10:37 PM
CraigSnedeker
Nov 16, 2009 08:25 AM
jfosc11
Tires and Wheels
Sep 16, 2009 09:26 PM
99Jimmster
Tires and Wheels
Aug 20, 2009 08:51 PM
Kingswede
Tires and Wheels
24
Aug 14, 2008 12:07 PM
