Help!! Wheels hitting on brake calipers??
Old Aug 27, 2009 | 11:06 AM
oktain's Avatar
^^^^ Long story short, grinding the caliper won't compromise anything, and proper spacers aren't cheap.
Old Aug 27, 2009 | 01:26 PM
dimone545's Avatar
dimone545 is an unknown quantity at this point
I agree.... Spacers are not cheap for good ones and in reality the caliper is so thick there that it wont hurt anything to grind it down a bit. Cheap spacer could do more harm than good. If it isnt centered correctly it could do alot of damage to joints etc.
Old Aug 27, 2009 | 02:22 PM
oktain's Avatar
I've seen wheel studs break because of too much stress, the rims didn't centre on the hub, they centered on the studs, if you get spacers you'd be putting alot of stress on those studs.
Old Aug 27, 2009 | 02:48 PM
matthew.chapman1's Avatar
matthew.chapman1 is on a distinguished road
These are different than hub spacers and that have no ill effect on any part of your wheels or joints...i got them from a place in Eagan, MN called wheel city.
www.wheelcitywholesalers.com
Old Jul 17, 2011 | 12:32 PM
wingsonmychevy's Avatar
wingsonmychevy is on a distinguished road
Default Same issue here!
I have the same problems here almost exact! I have a 2000 Blazer and i bought 22s for it and the front two rims grind on the brake calipers! If i decide to grind the calipers wouldnt i have a problem with it still when its time to change the brake pads? Really need help with this guys and gals!
Maxboost25psi
27
Mar 4, 2013 05:26 PM
spatula6554
Apr 10, 2012 02:17 PM
madblazerowner
Mar 2, 2012 04:13 PM
tick
Mar 13, 2011 10:40 AM
GABlazer92
Feb 24, 2008 04:22 PM
