Question??
Old Dec 4, 2006 | 03:29 PM
Dabber's Avatar
Dabber is an unknown quantity at this point
Default Question??
Okay now I am gonna start collecting things I need to put on next summer (Christmas is commin ) Cosmetic and otherwise. Okay This is what I am going to do next summer on a 05 Blazer 4X4. I am putting on a set set of 1 1/2 inch Shackles(soon to be ordered from someone ) then I am gonna crank my T-Bars about the same, Then seriously considering a 2 inch PA Body lift. Now the question I have is how big of tires can I put on my stock Rims(for now) The truck is mainly my DD and will see SOME off pavement adventures, Probably not flexing or stuffing like some of you but I do wanna try some stuff. I want to be able to drive the streets with min rubbing. I wouldn't mind a LITTLE TRIMMING But remember my truck is an s-10 blazer without flares like the ZR2 has. I do like the big wide stance look. Bows head..... Should have ordered a ZR2 instead. So anybody know.
Chris
Old Dec 4, 2006 | 03:38 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: Question??
if you just wanna drive the street and maybe trim a bit... 31's easy on stock height.... if you take it off road, id stick with 30's.... after the accessories, with trimming you coupld easily run 32's or 33's....
Old Dec 4, 2006 | 03:43 PM
Jigg's Avatar
Jigg is an unknown quantity at this point
If i were you, I'd do it in this order:
1: T-bar crank / shackles
2: Body Lift
3: 32x11.50 tires on stock rims with 1.25" spacers in the rear
Old Dec 4, 2006 | 03:48 PM
a_tack's Avatar
yes.. what he said
Old Dec 4, 2006 | 04:39 PM
Dabber's Avatar
Jigg..Thats' the order i was gonna do it anyhow, if not all at once. Glad to know I can fit 32x11.5. I guess the spacers for the back are another thing on the christmas list HAHAHA
Old Dec 6, 2006 | 02:53 PM
Dabber's Avatar
Okay I read on the PA site for the body lift. It said nothing about and modifications to the steering(or shaft). If i remember correctly i read somewhere that there is a mod to be done to that??
Old Dec 6, 2006 | 03:42 PM
a_tack's Avatar
no... there is no modification to be done to the steering shaft or shift linkage(i think thats what its called) with a body lift on the generation 2 s10 blazers.....
Old Dec 6, 2006 | 03:43 PM
a_tack's Avatar
no... there is no modification that needs to be done to the steering column or shift linkage on the generation 2 s-10 blazers with a 2 inch body lift...
2001Blue
Lifting Tech
Jan 1, 2011 07:15 PM
98Ltblazer
Apr 11, 2010 11:34 PM
Numba1Sean
May 6, 2009 11:48 PM
redfan13
Mar 11, 2008 09:37 PM
Chadoo951
May 6, 2007 07:01 PM
