TrailBlazer GMT360/GMT370 (2002-2009) Tech Have a 2002-2009 Trailblazer, Envoy, Bravada or Rainier? Post your general tech questions here.
Turn signal
Old Jun 2, 2010 | 01:52 PM
softtail's Avatar
softtail is an unknown quantity at this point
Question Turn signal
My 2007 trailblazer's turn signal inside is blinking fast, outside the bulb is not flashing at all. Bulb and fuse are good. What else do I need to look at to fix this? Thanks so much!
Old Jun 2, 2010 | 06:48 PM
Have you tested for power at the bulb? Which bulb is the one that is not working properly.
Old Jun 3, 2010 | 02:27 PM
softtail's Avatar
Thanks! There is no power to the bulb and it is the right rear turn signal.
Old Jun 3, 2010 | 04:37 PM
If the front turn signal works and the rear doesn't, the next step after checking for power at the bulb would be to check for power at the connector to the circuit board on back of the tail lamp housing itself. It'll be the dark blue wire.
Other than that, it's down to a wiring problem as the RT FUSE in the rear fuse box powers both front and rear turn signal bulbs.
Old Jun 23, 2010 | 10:26 AM
HARDTRAILZ's Avatar
HARDTRAILZ is on a distinguished road
The bulb may look good but probably isnt.
Otherwise some of the 360's had problems with the circuit boards, but are easy to replace.
SubbinBlazer
May 24, 2013 12:56 PM
ta3ff
Oct 14, 2009 05:07 PM
shaka1111
Feb 13, 2006 02:23 PM
jf_stan
Aug 15, 2005 12:43 AM
blazin97
Jun 15, 2005 05:51 PM
