97 Blazer - New Pump now no power to the pump.
Old 07-23-2015, 07:08 PM
RodneyB's Avatar
RodneyB is on a distinguished road
Default 97 Blazer - New Pump now no power to the pump.
I just replaced the fuel pump and now I dont have any power to the pump. I was having problems with the old pump but it still run so I had power before. I also change over to the new plug. I did check power at the splice and no power at the splice.
Old 07-23-2015, 09:48 PM
The grey wire at the pump module connector should have battery voltage for ~2 seconds when you initially turn the ignition to the run position. It should then drop to zero volts. Did you solder the connections when you spliced the new connector on? Do both black wires at the module connector show less than 5 ohms resistance to ground?
Chad Miller
12-09-2012 09:23 PM
antman94
03-05-2011 07:27 PM
frostblazer
01-25-2011 03:56 PM
Meanagersmom
06-13-2010 11:33 PM
stormshadow1
05-07-2009 01:18 PM
Quick Reply: 97 Blazer - New Pump now no power to the pump.
