Tranny Cooler question
Old 05-14-2014, 05:53 PM
jmparker82's Avatar
jmparker82 is on a distinguished road
Default Tranny Cooler question
I have a 2000 Blazer LT 4x4 with th 4L60E tranny. I am putting an aftermaket tranny cooler on it. Will it be better to just run the aftermarket tranny cooler and disconnect the factory one. Or run the aftermarket tranny cooler after the factory cooler as a add on?
I live in North Dakota so the winter temps is why i am asking. The tranny uses Dex VI so it is synthetic so it doesn't thicken or thin like coventional oil. Any suggestions would be appreciated especially if you live where it gets -30 out.
Old 05-14-2014, 06:53 PM
richphotos's Avatar
richphotos has a spectacular aura aboutrichphotos has a spectacular aura aboutrichphotos has a spectacular aura about
Most people have used both the factory and after market.
Old 05-14-2014, 07:26 PM
rexazz2's Avatar
Always a good idea to run in conjunction with radiator
In colder weather you can over cool the fluid
IIRC the install instructions should recommend the fluid passing threw aux cooler >> radiator >> then transmission
that routing should keep the ATF close to water temperature
Old 05-14-2014, 09:10 PM
jmparker82's Avatar
Thank You for the input. I am definitely keeping the radiator cooler connected then.
robjamber
02-01-2010 10:20 PM
smoke03
06-30-2009 02:18 AM
AutomagicLS1
Engine & Internal
12-05-2006 06:32 PM
Jetfixer
07-11-2006 05:02 AM
herskal
05-26-2006 11:46 PM
Quick Reply: Tranny Cooler question
