Noisy injectors
Noisy injectors
Hi everyone,
Let me first say thank you to all who share their knowledge on this forum. I am a new member but have learned alot from reading posts before joining.
I recently bought an 88 with TBI and the injectors seem noisy. They have a bit of a buzz sound to them. I have had this blazer about 4 months and this just started. Are they going bad? And how common is that?
I searched for this and didn't see any posts, any help is appreciated.
Patrick
Patrick
Check the injector pod bolts. There should be three of them if I remember correctly. If they are loose, it can cause quite a racket.
Also check the location of the fuel lines. They sometimes can hit the firewall at the back of the engine.
It is also possible that you have a restricted return line which is causing excessive pressure to the injectors. A restriction could come from a twisted or bent line. This can sometimes occur right where the lines enter the back of the throttle body if someone isn't careful taking the lines off.
The Beep
02-10-2009 09:08 AM
chevyman30571
02-26-2008 06:32 PM
Raider Fish
01-17-2008 02:38 PM
