General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
tranny wont go into park
Old 11-02-2006, 03:24 PM
fdva359's Avatar
fdva359 is an unknown quantity at this point
Default tranny wont go into park
having a little trouble with my 91. for some reason, its not catching park. just started happening the other day. when it rolls you can hear it clicking like its trying to catch. is it a simple adjustment problem or do i have an internal problem?? all other gears are fine.
Old 11-02-2006, 03:50 PM
4lowlife's Avatar
Default RE: tranny wont go into park
Check the linkage underneath. You may have to remove the tranny fluid pan to see what else is going on.
Old 11-02-2006, 09:41 PM
DetroitMuscle is an unknown quantity at this point
My 92 is doing the same thing, I have to smack the shift lever upwards towards park and it catches, its a linkage problem for me. If it goes into every other gear ok then its just the linkage if it wont go anywhere or moves freely its your gear shift selector arm, runs about 100-150 at a tranny shop.
Old 11-02-2006, 09:49 PM
93s15jimmy is an unknown quantity at this point
my dad used to have an 83 that did that. it happened after we changed the tranny fluid in it. my jimmy dosn't click when it rolls, it just won't go into park all the time and i have to slam it into park.
Old 11-03-2006, 04:19 AM
Chevy Lover's Avatar
It's either an external linkage adjustment or an internal problem with the parking pawl.
Old 11-03-2006, 08:29 AM
ORIGINAL: Chevy Lover
this one is the linkage adjustment. if its internal there would be slippage with the gear selector, like completely free movement.
Old 11-13-2006, 10:25 PM
mars004 is an unknown quantity at this point
I'm starting to have the same problem and I was told it is probably the bushings for the cable because there plastic and known to break. You should be able to see the shift cable from underneath the truck just follow it until you see something that is broken or cracked.
dj00140
05-20-2013 06:37 PM
budsiebeneicher@gmail.com
08-11-2011 10:18 PM
toolman243
06-04-2010 05:29 PM
er.rigney
06-04-2009 08:28 PM
Chakoose
03-27-2009 04:35 PM
Quick Reply: tranny wont go into park
