1991 s10 blazer rear defroster problem , help please
Old Dec 25, 2018 | 05:19 AM
Only available to me is the 1994, therefore you need to check if your 1991 is the same. I would guess that it is at least similar but YOU have to make sure.
Old Dec 25, 2018 | 05:38 AM
the rear struts act as the + and - for the defogger. This can cause more issues. The negative (ground) may be conductive everywhere, while the positive needs to be insulated towards the body, else it will short out.
Actually the strut is just an elegant way to connect the heating grid to the power and ground through the struts. It should be possible to fix it by soldering a wire to the remainders of the broken off connector. Or as you suggest having a cable run directly from the connector (female) to the grid but then when closing the window you need to take care of where that cable goes.
BTW. Greetings from Switzerland.
Yeah, shipping oversee is sometimes more expensive than the parts themselves.
Merry X-Mas
Old Dec 25, 2018 | 08:48 AM
vincent1972's Avatar
vincent1972 is on a distinguished road
Great and Thank you for the wiring diagram.
at first sight it seems to be the same as a 1991 model (they are almost the same)
i can not thank you enough for this information.
ps: my 1991 s10 blazer is imported from st-moritz Switzerland
Greetings from Belgium and merry x-mas and a happy new year
1985t10
Oct 20, 2013 07:54 AM
richphotos
Oct 19, 2012 05:16 PM
eyeblazin
Feb 7, 2011 09:55 AM
Rags58
Jan 19, 2010 06:21 PM
FlatTopFoley
Feb 10, 2009 08:21 AM
