has any 1 used this stuff before ?
Old 11-29-2011 | 05:51 PM
xgiovannix12's Avatar
yes i found the symbol for the resistance on the manual and its 67
  #32
Old 11-29-2011 | 05:58 PM
Too much, should be less than 5 ohms, that's why it's hot. Follow it back until you find the poor connection, or run a new wire, using 10 gauge wire.
  #33
Old 11-29-2011 | 06:03 PM
I followed it all the way to the driver side where the wire comes out of the body
i got lower once i got to the wire on the driver side by the body 65 resistance
  #34
Old 11-29-2011 | 06:04 PM
burning_soul07's Avatar
burning_soul07 is on a distinguished road
I had this same problem. Had to make a new connection to the window at the passenger side. Then had to track down where I had a bad connection. My bad connection was where the wire screwed into the arm, it was dirty and didnt get a good connection. After I cleaned both sides out the rear window defogger worked great again.
  #35
Old 11-29-2011 | 06:06 PM
can it be i have a problem in the harness ?
or the plugs that go on the struts have to be replaced
  #36
Old 11-29-2011 | 06:10 PM
Check resistance between the terminals on the strut, that should also be less than 5 ohms. Yes the problem could be in the harness, but most likely where it attaches to ground after it comes out of the harness.
  #37
Old 11-29-2011 | 06:17 PM
Ok i did this from the passenger side the wire from the body had 5 ohms so i connected it to the strut I tested at the other tip of the strut and i had 5 ohms now i connected the window wire and tested the grid and i had 5 ohms
I tryed the wire on the other side of the glass and i had 5 ohms I connected the wire to the other strut and had 5 ohms on the other end of the strut
When i test the wire coming out from the body on the drivers side it reaches 65 ohms
I guess i need to pull the rear panels off tomorrow
  #38
Old 11-29-2011 | 06:21 PM
Driver side will show volts, not ohms. All you need on the driver side is for it to show battery voltage when the defroster is turned on.
  #39
Old 11-29-2011 | 06:36 PM
so that means every things ok then right ? if i test the body wire from the driver side i get 13 volts
if i connect the wires all together the passenger sides ohms would be 67
Edit: I connected every thing again I tested every thing all the 3 plugs have 5 ohms and the driver side body wire has 13 volts
so i guess every things ok
edit2: I tryed it again and the wire hot real hot again sigh i give up for tonight
  #40
Old 11-29-2011 | 06:51 PM
You must check resistance at the wire connector on the passenger side, (ground) with the connector unplugged from the grid. Gotta be 5 ohms or less.
Quick Reply: has any 1 used this stuff before ?
