What water pump to buy? Blazer 1993
Old 11-13-2013, 09:12 AM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
Originally Posted by Smitty Smithsonite
Not to confuse anyone .... just an FYI:
All 4.3 water pumps will fit all 4.3 engines from '87 to '05 - the TWO differences between 1st gen and 2nd gen (yours is a 1st gen)are the pulley (one is a V-belt, and one is serpentine(you have serpentine) and the fan clutch style (one mounts with 4 bolts(you have the 4 bolt style), and the other, just one large nut in the center). There is also a V- belt and serpentine style that both use the 4-bolt mounting of the fan clutch - that setup would be easier to swap back and forth. The different style pulleys change the distance from the engine the belt runs, so changing from one to the other is not easily possible.
All the bolt holes are the same on the blocks of 1st & second gen engines - only difference is 1st gen is SAE threads, 2nd gen is metric. Everything will bolt right up from one to the other - you just need the hardware .. and on a second gen you;d have to remove a stud or 2.
Again, just FYI for those who want to know. Buying the correct pump for your year-model is the easiest way to ensure a bolt-on-and-go setup with no modification.
You nailed it. But to help the op out i'll bold edit some stuff.
Originally Posted by Gio
Well, am kind of lost already. More I read and look more confusing the damn thing is.
Different brands, different numbers, the pulling or pushing type - on man.
I just uploaded some photos of my pump to: Blazer - Blazer
Hope it will be clear enough to see what exactly I have. I don't have that hexa bolt like some have.
Sure would like to finish this ordeal.....
At this time it doesn't matter if they ship to Europe or not - I just need the exact pump.
TIA
yep,you have what i have on my 93. Just make sure you get a pump from a 90-93 model.you could go earlier or later but 100% for a fact those years i gave you is exactly what you need. Since yours doesnt have a nipple,if the one you get does have one you can just go to the hardware store and find a plug for it. no big deal. Oh,take them studs out of your old pump before trashing it. the new one wont come with em.
Old 12-10-2013, 03:59 AM
Gio's Avatar
Gio
Gio is offline
Gio is on a distinguished road
Talking
Water pump arrived and it's installed. Everything is perfect.
Thank you ALL for your BIG help....
Old 12-11-2013, 08:25 AM
Smitty Smithsonite's Avatar
Sweeeet!
4.3vortec
04-01-2014 09:17 PM
big_charms@hotmail.com
03-25-2013 08:12 PM
mikekolb
07-26-2009 11:59 PM
countryguy1713
06-16-2008 06:53 PM
jes9999
01-01-2007 06:12 PM
Quick Reply: What water pump to buy? Blazer 1993
