2000 blazer zr2 clicking under passenger dash??? Please help
#21
Clicking/Hazard Switch
Bernie, I stuck the plastic tube from the contact cleaner spray can into the gaps around the hazard p/b. I sprayed 3 second bursts while rapidly operating the hazard p/b at the same time...plus dozens times more while not spraying.
This evidently cleaned enuff crud off the contacts to stop the annoying flasher relay clicking.
Again, put a rag beneath the steering column to catch the spray run-off.
#22
I have a 1999 Chevy Blazer with the radio controls on both sides of the steering wheel. I am trying to replace the multifunction switch. I disconnected the battery and took out the air bag fuse. On both sides of the radio controllers on the steering wheel, I see the clips to push out to release the air bag. I have 1 torx screw and 1 clip on both sides. I see a lot of people posting about 4 clips. I am figuring because this blazer came with the option of the radio controllers also on the steering wheel that this is why I only have 2 clips? I am not sure but would like some help to confirm? Also how to these clips pop out?? I am using a flat head screw driver but have had no luck. Anyone with some information, pictures or video would be greatly appreciated. I can also give my email if this helps. Really want to get this over and done with. Thanks Bernie
No need to remove the steering wheel.
#23
im not having this problem, but in previous trouble shooting involving a short in my flasher relays i found that there was a recall on the MF swtich for my 2001 blazer so before you drop 100 bucks on a new one, go to the dealer and milk them for everything they are worth
gnpower
11-28-2010 09:29 AM
CompTechMike
07-16-2010 03:55 AM
enigmattic
01-02-2009 09:06 AM
apekim
09-15-2007 10:46 AM
