96 blazer park/trans. problem
Old Aug 23, 2008 | 03:01 PM
mudd4's Avatar
mudd4 is an unknown quantity at this point
Default 96 blazer park/trans. problem
I have a 96 blazer that when in park if it is on a hill/slant or you lean against it hard enough it will slowly slip and move. Any one have this problem? I have been told it could be the cable out of adjustment or bad. Or it could be something in the trans itself. Just want to see if anyone has any ideas before I have to pay to have someone look at it. It is also a little hard shifting out of park, probably from the tension on it. It has 125,000 miles and I purchased it not knowing about this problem.
Thanks for any help!
Old Aug 23, 2008 | 04:22 PM
WolfPack's Avatar
Default RE: 96 blazer park/trans. problem
Do you have the auto 4wd? If you do, a transfer case failure/front diff failure can result in driveline failure not allowing Park to hold the vehicle!
Old Aug 23, 2008 | 05:50 PM
mudd4's Avatar
ORIGINAL: WolfPack
Yes it is all wheel drive. What type of failures would do that? Something I need to take in and have looked at to find the actual problem? Or is it something I can find out on my own? I'm not a mechanic, just a back yard mechanic. I'm hoping someone could tell me how to adjust the cable or how to tell if it's bad. Hopefully it's not something major!!
ksunday1
Nov 5, 2013 02:22 AM
grounded87
Jun 29, 2011 09:12 PM
pgerenday
Jun 20, 2011 03:53 PM
vrryder
23
Dec 30, 2009 01:07 PM
rob1621
Feb 29, 2008 08:15 PM
