brake squeeking/grinding noise
Old Jan 30, 2012 | 11:31 PM
99bblazer99's Avatar
99bblazer99 is on a distinguished road
my hub bearings are are only 5 months old. ive had this problem bfore and the fixed it but im thinking its the same problem there just trying to get me to get somthing fixed thats not needed. if it is rubbing wouldnt i bend it backwards
Old Jan 30, 2012 | 11:46 PM
scottl1346's Avatar
scottl1346 is on a distinguished road
Originally Posted by Rottidog
It may be the dust plate, nothing to do with ABS is all I'm saying. He may have to bleed all the brakes, starting from the PS rear, then DS rear, then PS front & DS front, in that order!
I'd be weary of a hub bearing failure & like gio/geo said, lift the front & spin the tires, then I'd feel for where the issues is coming from. If you can get a mechanics stethoscope then that would be a bonus because you could come closer to pin pointing it.
the abs sensor is part of the dust plate! i think you model is different its screwed into the hub instead of mounted on the dust plate that why i posted a pic of it
Old Jan 31, 2012 | 12:04 PM
Rottidog's Avatar
Yeah my '02 has the ABS in the hub.
Old Jan 31, 2012 | 01:15 PM
so would would i bend tword the wheel or away from it
Old Jan 31, 2012 | 08:18 PM
scottl1346's Avatar
away you dont want it to rub the rotor just jack up the tire and spin it by hand if its rubbing you will hear it. does it do it all the time or more when your cornering?
Old Jan 31, 2012 | 08:43 PM
mainly when I turn going slow like through a drive through. but today after work I pulled both tires off and found that they had been rubbing so I beat both them back and it does it sometimes but its alot better then what it was. now i got work on getting my brakes to stop squeekin
Old Jan 31, 2012 | 09:19 PM
scottl1346's Avatar
thats when mine where making that grinding sound turning going slow. squeaking brakes could be anything from a little sand to not using brake grease on the back side of the pads i wouldn't worry about it to much
PoppaJoe
Jan 8, 2012 08:23 PM
kruegersck
Mar 12, 2010 05:59 PM
96Ls4Dr
Mar 25, 2007 03:48 AM
jadewolf32
Mar 9, 2006 01:32 PM
V6 Vortec Jimmy
Apr 29, 2005 12:03 PM
