Break light on no rear brakes
Old Mar 1, 2019 | 04:38 AM
Cole Johnson's Avatar
Cole Johnson is on a distinguished road
Default Break light on no rear brakes
Had the plastic by steering colume off to hook up double din that all works fine but have break light on an noticed when backing down drive way I will hit my breaks an only my front breaks lock up an nothing in back for breaks
Old Mar 1, 2019 | 07:07 AM
cleburne red's Avatar
Were the rear brakes working before? There's nothing in the dash that would make the rear brakes inoperable. They're mechanical, nothing electric
Old Mar 1, 2019 | 08:08 AM
Yes I'm pretty sure they did but I notice I have a 6 pin plug unhooked an can't seem to find where it goes
Old Mar 1, 2019 | 08:26 AM
LesMyer's Avatar
If you back down a sloped driveway and hit the brakes, the fronts will lock up much more easily than the rears. Probably no problem there. As for the light, check the emergency brake - it may be slightly depressed or switch may be misadjusted or bad. Probably you did something with the e-brake when working around the steering column.
Old Mar 7, 2019 | 12:27 AM
Trukntigger's Avatar
Depending on your options you will have a few connections that may not have a “home” to plug into. If the brake light was not on before the double din radio work I would suspect might have bumped the emergency brake a notch and tripped the light on. If you had accendently unplugged it no light would occur. That said easy check first, look at brake fluid level under hood. Low fluid will give a indicator light. How low your brake pedal sit. WHen the pads wear down a good amount the pedal general sits lower and fluid drops. Lastly, the usual- normally the pads have metal tabs that will rub on rotor making a squeal sound to make the driver aware the pads need replacement soon. So- check your stuff, brakes are a working in good order necessity.
Old Mar 7, 2019 | 01:00 PM
Mike.308's Avatar
I'll bring the wise tip here over again. Do You have the fluid in the tank? Maybe You have a brake liquid leak? Any traces on ground?
fattest1here
Mar 29, 2011 08:11 AM
m3ch
Aug 2, 2010 07:06 PM
Hizapitt
Jun 23, 2010 06:03 PM
ff_malone
Jan 7, 2010 12:25 AM
cool2drblazer
May 16, 2006 04:49 PM
