Daylight Sensing lights & keyless entry won't work
RE: Daylight Sensing lights & keyless entry wont work
Ok, after working on the Blazer for about 3 hrs last night and then pulling it (towing) to my brother-in-laws garage. We stillcouldn't get it to start, the battery was completely dead, and there was fuel pressure up to the block. So my brother-in-law did some more reading and found this link to what we think is the solution to the whole problem, the Ignition switch. Here is the link: https://blazerforum.com/m_145330/tm.htm
This second link is a link that swartlkk posted on how to fix the problem: https://blazerforum.com/m_142449/tm.htm
I will post once we get the part in and it hopefully starts up. Thanks to everybody for the suggestions and direction on what to check.
ORIGINAL: rdhack
Hey I larnt somthing today. Now I know how to turn off them darn daytime lights on my wife's Bravada!
***Update***
Ok, so we switched out the ignition switch, and it still wouldn't do anything. So we checked all the connections, my brother-in-law cleaned out the lock cylinder, and still nothing. I borrowed a scan tool, and my brother-in-law tried to clear the security light, and nothing. So tomorrow, calling up a tow company and getting it towed to a shop. I've heard that they think the computer is locked up, and you need a Tech II or equivalent, to get it going right. Will post what the shop says is wrong, once i get it back. Thanks again to everybody who tried to help me out.
Solution to No Start, and Electrical Problems
*THE SOLUTION*
Ok I just got my Blazer from the shop, and $345 later, it turns out it was 2 wires. One was in the wiring harness going to the BCM, and the other was coming from the BCM to the ignition switch.
Thanks againfor everybody's advice.
Bonsee
04-19-2011 08:03 PM
civickid
09-07-2008 11:42 PM
