The difference of a day.
Old Mar 27, 2012 | 02:40 PM
Chevy33's Avatar
Chevy33 is on a distinguished road
Default The difference of a day.
Yesterday, while working on the 95 Jimmy swap; the motor tune was way out of wack. I managed to get the throttle stop torx screw out of adjustment not knowing what I was doing and now know why it has a cap. I could not get the idle and the throttle response to jive. I either had good idle and no throttle or throttle and poor idle. I tested the fuel pressure and it was good. After testing all the sensors with a multi-meterI and finding all the sensors in range I accidentally moved the throttle open a little and noticed the idle settle down. After adjusting the throttle stop torx the problem is solved. Yes, I know I shot myself in my foot to begin with by messing with this screw but I learned some valuable information. I've come to the conclusion what was causing the original problem was the MAP sensor. I don't think it was plugged in properly.
Sometimes we must go backwards to move forward.
Old Mar 28, 2012 | 11:23 PM
onebadsuv's Avatar
onebadsuv is on a distinguished road
MAP sensor improperly connected ? But the three wire plug should fit one way only as the slot is keyed ...
however , yesterday I had fun swapping out seemingly good MAP sensors on my '95 with (junk yard pulls for testing) and they all made the 4.3 engine run a little differently - none set off the check engine light . One was quite an improvement in drive-abilty and throttle response
Blazerdazed
Oct 18, 2010 07:58 PM
Pugsley
Feb 2, 2006 10:08 AM
Canadian88
Jan 27, 2006 05:20 PM
ivannj
Jan 20, 2006 04:38 AM
ivannj
Dec 24, 2005 10:46 AM
