Front driveshaft hitting motor!!!
#21
I'm thinking it has to be something amiss with the motor mounts. I'm not exactly sure on the s-series trucks, but I know quite a few older vehicles have the motor offset to one side.
How does the fan shroud to fan fit look? (2nd time)
#22
OK, more info:
The fan is perfectly centered in the fan shroud. Advance Auto originally provided me with the wrong part, I exchanged for the correct mount (same part #, different box) that is supposed to go in there and it is the same height as my original mount.
Is the 'knuckle' of the u-joint supposed to be in front of the bellhousing? I might be able to move the motor back about 1/4". The mounts on the motor are adjustable front to back- I have to check the holes on the crossmember for room tho.
#23
Does anyone have a pic of their u-joint to motor clearance?
I bought some new front shocks, hopefully these will get ride of some of the bounce.
#24
Sorry, can't help ya on the picture; mine's a '98 and has a slip joint at the transfer case end of the prop shaft.
#25
If I'm not mistaken, the u-joint you see in the picture he posted is up at the front diff.
#26
Correct, I'm looking for the u-joint near the front diff...
#27
I installed a new trans mount, and there is about 3/8" between the front driveshaft and the motor. This still seems awful close. How much clearance should there be? Could someone snap a pic?
#28
3/8" should be sufficient considering the mounting used for all of the components.
#29
Many thanks, the driveshaft no longer hits. The transmission mount was bad, and this was compounded by bad shocks.
gitch93
01-23-2013 04:51 PM
Blasir
02-07-2007 09:07 PM
trudynosports
12-13-2005 09:40 PM
