Fuel gauge non-functional
If your gauge reads full all the time you have a break (open) in either the black sensor ground wire or the purple signal wire. If it reads empty you have a short to ground.
You need to follow the wires from the sender to the PCM looking for damage, particularly around connectors. Quite often when engine or transmission repairs are done those wires get pulled out of their connectors along the way.
In regards to the GeorgeLG questions I'd rather assume there could be something wrong with a VCM settings or a damaged input. But the damaged input check is as easy as finding if the "low fuel" indicator gets triggered. If it does, the input is ok.
I guess he wouldn't have 80 Ohms reading then.
between the wires coming out at the pump.
It would see 0 or infinity.
If the feedback line is shorted - it is shorted on both ends.
Whatever.
Not going to argue schematics. Point is if the sender is operating correctly, which it seems to be since 80 ohms is around 1/4 tank, then he needs to follow the purple and black (possibly with a white stripe) back to their sources and find what is damaged.
I'd start by re-connecting the sender and see if he gets 80 ohms across c3 13 and c3 19 at the PCM. C3 is the clear plug.
Splice pack 422 on the LH frame rail, right by the transmission crossmember is a common place for damage and corrosion.
Neither do I. I didn't mean to be rude, just give a pure engineering advice (short circuit are excluded). Btw. we did not mention grounded wire...
mjcobe89
09-10-2009 09:02 PM
illinois99blazer
13
12-02-2008 07:20 AM
Mulisha
03-24-2008 09:14 PM
