Having a hard time seeing gauges in daytime
Old Feb 20, 2019 | 12:43 PM
don james's Avatar
don james is on a distinguished road
I'm just being picky i guess.......most of the time i can see what number the needles point to, but when the sun is coming in.....forget it.....especially with sun glasses on,,,..
the needles are very visible,I just have trouble seeing exactly what number they are on............good example would be going thru a school zone.........5 mph.........could mean a lot to the billfold....
2001...by the way
Old Feb 21, 2019 | 08:47 AM
go chevy's Avatar
Ohhh, I gotcha lol... It is not the back lighting of the dash itself... As far as the sun blinding you I have no idea how you can really do much about it... If you do find some kinda neon bright setup let us know
Old Feb 22, 2019 | 03:30 AM
Mike.308's Avatar
...or a polaroid eyewear.
Old Feb 22, 2019 | 08:49 AM
go chevy's Avatar
2001...by the way
I just recently bought 2 Tac Visors, you see tv commercials all the time on the weather channel. They are amazing!!! I don't even use sunglasses in the Blazer anymore.
Old Feb 23, 2019 | 06:52 AM
don james's Avatar
I'll try some different sunglasses.......snow cover and colorado sunshine makes the gauge cluster much harder to read.............but i'm still working on some other ideas........
Old Feb 26, 2019 | 12:38 PM
jimspahr@msn.com's Avatar
Don james, what year and model SUV do you have ? What type gauges are you having trouble seeing ? I have a 2003 Blazer LS and have trouble reading the digital read outs like the odometer. The 'dial with orange needle' gauges like the oil pressure, coolant temp, gas gauge, speedometer, tach/ RPM, are all very readable. The digital gauges fade out in certain light conditions to the point they are unreadable. This is in the day time when the sunlight strikes them at a bad angle.
One trick to read these small digital numbers in bad lighting is to turn the thumb wheel down to the lowest setting. So turn the wheel DOWN.all the way. This causes the gauge backlighting and the dig. odometer read out lighting to increase just enough to make those digital numbers readable. I discovered this trick by accident. This may only work on 2003 era Blazers. The odd thing is this thumb wheel is usually turned the opposite way to make the rest of the dash lights brighter ! Try it and see if it works on your vehicle.
Old Feb 26, 2019 | 03:01 PM
don james's Avatar
I don't have digital gauges.........my only problem was making out the numbers,..I can see the needles fine.......just not enough contrast between the panel color and the number colors.....I am making progress ..........thanks for all advice.........
rosie
Oct 8, 2011 08:10 PM
luiguiv
Jul 30, 2010 08:58 AM
1986blueblazer
Feb 18, 2010 11:05 AM
Blazer_boy
Oct 28, 2007 12:47 PM
AW90
Aug 15, 2005 10:32 PM
