Parking brake magically wont work
Old May 9, 2010 | 09:51 PM
  #21
RangerG's Avatar
Originally Posted by zedartwo
I swear you better give me a heads up if a head gasket or something major goes lol. My parking brake started not working. My pedal works fine, Its just the shoes don't seem to have enough pressure to keep it from rolling.
Hows about you go change your oil lol. Maybe mine will magically change lol. J/K
Good luck with the brake tho. I'm gonna get mine looked at by my uncle. He owns an alignment and brake shop, so its a given hes doing it lol.
I'll be sure not to go roll my blazer over in a ditch, yours would be soon after!
I'll go get my oil lines fixed and you go get the parking brake fixed. We'll meet back here and exchange plans!!
Old May 10, 2010 | 01:26 PM
  #22
KRUSHER's Avatar
KRUSHER is on a distinguished road
Same thing happened to mine, it was working and one day it wasn't. I just havent took the time to look at it Most likely the ratchet mechanism.
Old May 10, 2010 | 05:44 PM
  #23
zedartwo's Avatar
Mines gonna get fixed along with my AC. I have an awful screeching coming from it and the clutch no longer engages. Im gonna grab one from a wrecker and have my uncle do that too lol.
Old May 10, 2010 | 05:56 PM
  #24
RangerG's Avatar
I tried to get my oil lines looked at. I didn't try very hard though...
Local repair shop that I wanted to take it to wasn't open. They may have shut down, which isn't a good sign...
I also took it to the dealership "just in case" they had a reasonable offer. They won't even give me a ballpark quote without having it diagnosed first, which is a $40-100 ten minute look to tell me what I already know...
Old May 10, 2010 | 06:00 PM
  #25
zedartwo's Avatar
Just r pull your front skid plate. You'll see very quickly of its them. Had mine off to do my belt!
Old Jun 22, 2010 | 05:37 PM
  #26
h2kgolden's Avatar
h2kgolden is on a distinguished road
Had the same issues as the OP. (Parking Brake pedal wouldn't stay down). '98 Blazer.
Following the link posted to a picture of the assembly, I was able to locate the bolts and nut to get it off.
Once off I found that the end of the coil/spring that loosens, thus letting the brake release, was stuck on the plate above it. So instead of resetting itself to the tightened position, it was stuck loosened, which allowed for the pedal to move freely. I was able to free it with a screw driver and it works fantastically again. I'm puzzled as to how it go stuck on something ABOVE it's normal range of motion, but I'm just happy it's fixed.
Thanks and I hope someone else with this issue reads and gets an easy fix as well!
Old Jun 22, 2010 | 06:05 PM
  #27
RangerG's Avatar
Good work! Mine will be coming off in about a week or two. I'm hoping it's like yours and just need to be reset. A new one costs $103 from Chevy, so that's not too bad either.
Once again, good job getting to the bottom of this!
Old Oct 3, 2010 | 08:09 PM
  #28
RangerG's Avatar
This year long problem is now starting to give me grief.
Twice now I've taken apart the panels to try and get the parking brake out. I've taken apart every interior panel that is anywhere near the assembly, but I cant reach one nut.
It's the one labeled "nut" in this picture.
You require a deep socket to be able to reach the nut past the end of the bolt, but I have a cluster of a million wires blocking it. I can shove them just a little, but not enough to fit the socket and wrench past, or to put my hand in to I can find the nut.
I really don't want to have to take this to a shop at $110/hr.
Old Oct 3, 2010 | 08:19 PM
  #29
zedartwo's Avatar
Why is your interior red?
Oh and I will be doing this soon so hopefully one of us figures it out.
What about just a wrench?
Old Oct 4, 2010 | 10:32 AM
  #30
RangerG's Avatar
Haha that is just a pic off s10-forum to show what I'm talking about.
You can see here that the nut is kind of blocked by the plating for the assembly. I had to reach over the plating just to feel if the nut was there, so no way I could get a wrench in there.
Those pics are from a s-10 pickup truck, so I'm thinking there are differences in the panels blocking it and the wiring in front, because the guy with the pics got his out no problem.
ABSLT
Aug 31, 2012 11:46 PM
slammed95blazer
Oct 27, 2010 07:24 AM
red man 1990
Jul 28, 2010 07:21 AM
xderkax
Jan 14, 2010 11:38 PM
corvette535
Dec 14, 2008 02:47 PM
