Removing headlights.
I am assuming that a Jimmy is the GMC version of the Blazer. So therefore I have come in search of knowledge. The Jimmy I am looking at is a wreck. Needs a good detailing and I have plans to follow the de-oxidizing headlights procedures but I need to know where to start with removing the headlights. Any help could be of assistance. Thanks ![Smile](https://blazerforum.com/forum/images/smilies/smile.gif)
Nathan
Nathan
i think their is two clips for each light but thats for a blazer just pull up on them
Yeah, there are two plastic clips per side that are located behind the radiator core support. Pull up and they will release the light, then you have to tip the top edge of the light out and pick up to disengage the tabs from the slots in the core support. Disconnect the wiring and it'll be free.
Well, that is for any '98+ Jimmy anyway... Not too sure on the '96-'97...
Well I'll let you know something tomorrow. I'm picking it up and heading to work after picking it up. I'll be sure to take before and after pics :O
96 is different. Book says to remove battery and air cleaner box for access from the back - pain in the butt.
However easiest way is to remove the grill and unbolt the light assembly'sfrom the adjustment frame -they will fallforward into your hand. Out and back in takes about 30 minutes.
Sounds easy. Steps for removing the grill?
if it's a 94 just look for the screws, they aren't hard to find on the grill, open the hood to, there is someon the top i beleive.
hollywoodgrad
01-25-2012 01:58 PM
Crestwood1001
05-31-2009 10:45 PM
