Starter Key Lock sticks in 'OFF'
Old Jan 21, 2012 | 11:51 AM
bgda's Avatar
bgda is on a distinguished road
Default Starter Key Lock sticks in 'OFF'
2000 Blazer - the key sticks or hangs up in the off position often. I have replaced the key lock and no help there.
It appers that the key cylinder housing has 2 pins that meet up with detents in the lock mechanism.
Can I cut those off to allow the lock to turn freely?
Old Jan 21, 2012 | 12:10 PM
bgda's Avatar
A little more detail -
Insert the key - I have to wiggle the lock back and forth before it will move forward to the 'Run' or 'Start' position. works fine then.
goes back to the 'off' position without a problem.
Try to 'Start' again - it will often stick. Same thing happens when trying to go to 'ACC'
I hope someone have a great idea for me!
Old Jan 21, 2012 | 12:12 PM
Gale's Avatar
Gale is an unknown quantity at this point
Question Try making sure the wheels are straight ahead.
Not total sure what you mean by 'locked'?
If I park with the wheels cut then shut it off sometimes it will bind so I just cut the wheel a bit to remove the pressure so I can unlock it on 2002 Blazer.
For the first few weeks with the 1998 S10 we just got I was fighting with the button by the key to remove the keys but it was a new user thing because I now do it without thought.
Panzer
Mar 4, 2012 04:03 PM
Fozzy
Feb 6, 2012 10:49 AM
thebigjimmy
Nov 14, 2008 06:09 PM
SkylineGTSt
14
Oct 24, 2007 03:44 PM
sketch12
Jan 12, 2006 07:26 PM
