Thunka-thunka-thunka over bumps
Old Feb 22, 2018 | 04:04 PM
puttster's Avatar
Default Thunka-thunka-thunka over bumps
Sound is coming from behind the glove box, not a metallic clanking, more of a knocking. Can get up to several times a second on an old brick road. KnockaKnockaKnocka... Shock tops and a sway bar bushings and links look ok. Upper control arm boshings look thin but no play in the wheel.
Im not sure how long its been knocking. I did hit a curb last month on the other side, knocked out the alignment. I fixed the toe but it might have affected the idler arm. The tie rod has some play. The plastic box that covers the a/c is where the noise seems to be coming from is falling apart ... anyone recognize that sound and know what part is loose?
Old Feb 22, 2018 | 08:13 PM
odat's Avatar
check your hood hinges for play
Old Feb 22, 2018 | 11:18 PM
puttster's Avatar
I got the good washers a couple of years ago. That was more of a metallic sound. This has more of a bonka, bonka, bonking on rubber sound.
Old Feb 23, 2018 | 01:18 AM
odat's Avatar
OK you had that covered - often over looked is the body mounts, you might want to check them out for sh--s and giggles
Old Feb 27, 2018 | 08:29 AM
El_Beautor's Avatar
Could check your shock bushings too. I had one fall apart on my Blazer and the shock bolt was rattling in the mounts.
lionel2
Aug 31, 2012 09:26 PM
AKPerry
Nov 3, 2011 11:38 AM
Chevyboy28
Jun 11, 2009 02:06 PM
BrokenBlazr
Feb 26, 2009 08:16 PM
Nick Bain
Feb 25, 2009 03:58 PM
