Rattle on Right side of Blazer when going over bumps!!
Old Aug 25, 2012 | 05:28 AM
lionel2's Avatar
lionel2 is an unknown quantity at this point
Default Rattle on Right side of Blazer when going over bumps!!
Hello all, My 2000 blazer is making a rattling sound from the right side of car when going over bumps. Any idea what might be loose or the problem?? I checked the exhaust pipes, looks good there. Sound like a piece of metal flapping around. SHould be easy to spot, but I see nothing out of the ordinary.
Old Aug 25, 2012 | 09:15 AM
aa21830's Avatar
aa21830 is on a distinguished road
Front or rear of vehicle?
2-door or 4-door?
Old Aug 25, 2012 | 09:35 AM
Rottidog's Avatar
4wd, 2wd?
Could be a door bushing, heat shield for the exhaust, cat rattling etc etc.
We need more info other than a rattle somewhere.
If it's a duller sound & sounds like it's coming from under the dash I'd take a small rag, fold it over a few times & put it between the hood & weather seal by the hinge on the side it seems to be coming from. If the sound goes away you need to get new conical washers for the hood & replace them.
Old Aug 25, 2012 | 03:30 PM
step66's Avatar
I'd be interested in the response as I have a similar issue on my 97: right side rear.
Kind of a musical:ting ta ting. Already checked (by hand) the stabalizer and shocks. I know I wlll not be able to replicate the noise in my driveway,but all the bushings look servicable and have no noticable play. It does not seem to be a rear bearing issue as it is consistant with suspension action....and no:the exhaust is not contacting any thing and is solid!
Let us know! Thanks in advance!
Old Aug 26, 2012 | 04:29 AM
lionel2's Avatar
Its a 4 dr. 4x4 and it sounds like from the rear. My guess would be some where from the exhaust. I have the stock pipes on there now. You think it might be the cat? Humm. I read somewhere when they go bad they make a rattling sound. Still looking under the car, found nothing yesterday, will look again.
Old Aug 26, 2012 | 11:16 AM
Rottidog's Avatar
Punch the cat from underneath & listen.
Have a friend hit the tail pipe while you're under it (wear safety glasses) & see it the exhaust hits something, like the rear axle or a hangers' rubber bushing is worn away.
Old Aug 31, 2012 | 08:48 PM
lionel2's Avatar
The rattle is gone all of a sudden. No worries now.
Old Aug 31, 2012 | 09:26 PM
Rottidog's Avatar
Sounds like the cat is getting plugged up & deteriorating. Any codes & not just the CEL but have it scanned to see if there are any impending codes.
mdabbs
Jul 15, 2015 08:19 PM
meatbag
Sep 24, 2012 10:26 PM
Chevyboy28
Jun 11, 2009 02:06 PM
BrokenBlazr
Feb 26, 2009 08:16 PM
Nick Bain
Feb 25, 2009 03:58 PM
