vaccum resovoir
Old Feb 9, 2009 | 01:47 PM
01XtremeLT1's Avatar
01XtremeLT1 is an unknown quantity at this point
Default RE: hesitation in 2000 blazer
With the air filter as dirty as you stated its a good possibility the maf is dirty too. be extremely careful cleaning the MAF. Do not break the wires or you will be buying a new MAF.
Old Feb 11, 2009 | 12:50 PM
bammontana's Avatar
bammontana has a little shameless behavior in the past
The vac resovoir is right in back of the abs assemb in the fender. If you look down behind the abs assemb you will see a nipple coming out, that is where you have to plug it in.
Old Feb 12, 2009 | 05:22 PM
keithduke65's Avatar
keithduke65 is an unknown quantity at this point
crankshart position sensor? what is it and is this the problem i have with a 2000 s10 blazer? the blazer does not run good unless im accelerating. if you start off slow it hesitates ? start off fast it just takes off. on the highway going around 100k you can feel hesitation if your just going along? help?
Old Feb 13, 2009 | 04:14 PM
xwhere is the diy section
Old Feb 14, 2009 | 12:31 PM
Tech Articles (DIY). Just above the General Tech section.
Old Feb 15, 2009 | 06:37 PM
i did the vise grip test with the 4x4 and it works perfect. so now i have a vaccum problem? i was thinking about hooking up the wet vac and listen for the hissing. or driving water trough. the tri connection on top of transfer case when i chrcked it last week was loose so does this mean i have to haul the tc out. i really appreciate your opinion swartikk? you are a really good technichian ty
Old Feb 16, 2009 | 09:38 AM
Tony H's Avatar
Tony H is an unknown quantity at this point
Default RE: vaccum resovoir
ORIGINAL: 01XtremeLT1
Thanks for the reply to his question. I was researching all day yesterday and today trying to find out what a vacuum hose was that went to the motor with a check valve and a tee as you described here. I have tried looking for the reservior from the engine compartment but the short hose would be only long enough to hit the fender area.. approx 4" long. I guess its time to remove a fender and connect her up. This will now finish my LT1 installation.
Thanks again!
No need to take the fender off.
Stand along side the Drivers side fender, look down at the ABS system Look at the bolt that mounts it to the car on the Right hand side of the ABS. directly under that is the nipple.. you do have to reach back to the fender though. I just replaced that dried up hose Sunday. It's done blind though all feel.
Old Mar 2, 2009 | 03:34 PM
Not that anyone has replied to this thread in a while, but lets move the hesitation discussion over to THIS THREAD and let the "vacuum resovoir" discussion continue here if need be.
Blazerboy1611
Feb 24, 2010 06:48 PM
shanes
May 5, 2006 01:23 PM
djestes
Jan 2, 2006 01:29 AM
ron36535
Dec 28, 2005 04:05 PM
BUDWZR8
Dec 21, 2005 11:31 PM
