Will low or empty rad stop my truck from starting?
Old Dec 14, 2010 | 03:40 PM
Trede's Avatar
Trede is on a distinguished road
Default Will low or empty rad stop my truck from starting?
Hi, I tried to start my truck yesterday and it turns over but wont stay running, today I looked it over, the only thing I have found so far is the rad looks either low or empty, does anyone know what could be wrong, the oil looks OK and I dont see any leaks anywhere
thank you!!!!
its a 95 blazer 4x4
Old Dec 14, 2010 | 04:03 PM
step66's Avatar
No, a low cooling system will not keep it from starting-You have either a fuel delivery problem or something ignition related...any check engine light? If not,start with a full inspection of fuel lines and the coil/distributor/module/plugs and wires. Might be a plugged fuel filter as well... Time to trouble shoot! And then you need to find out why your cooling system was low! Good Luck!
Old Dec 14, 2010 | 08:03 PM
Mark_D's Avatar
Mark_D is on a distinguished road
Prob not the case unless you noticed your temp needle being high while driving in the past, but I think driving for a long time with the engine really hot could cause it to seize when it cools down. Like I said, I think it would take a lot of overheating to cause that though.
Good luck
dannyb91979
Jul 16, 2013 06:08 PM
AuSSenseiter
Jan 15, 2011 09:16 PM
Bob'sblazer
Engine & Internal
Dec 19, 2010 11:09 PM
DiRK
Oct 18, 2006 04:22 AM
PawNtheSandman
May 2, 2005 11:15 PM
