'05 Head Unit Replacement
Old Apr 23, 2005 | 11:27 PM
nomad45's Avatar
nomad45 is an unknown quantity at this point
Default '05 Head Unit Replacement
I'm planning on replacing my stock head unit with my Premier DEH-P630 that i've used in the past.
My local car audio retailer is informing me that i need some sort of bypass modules and/or chime modules to install the aftermarket stereo. These bypasses total about $140 all together, plus the dash kit, etc.
I'm just wondering if anyone knows if this type of thing is required. I heard somewhere that the blazer was the last to not have the airbags or abs hooked up to the stock headunit. If anyone can confirm one way or the other (if i'll need bypasses or not), that'd be great.
Thanks
Old Apr 24, 2005 | 03:21 AM
FatRyan's Avatar
FatRyan is an unknown quantity at this point
Default RE: '05 Head Unit Replacement
if you have the BOSE system, youll hafta get those bypasses to bypass the airbag stuff. it sux.
Old Apr 24, 2005 | 01:18 PM
nomad45's Avatar
Its not the bose system, just the regular RDS cd player (no tape player).
Old Apr 24, 2005 | 05:20 PM
FatRyan's Avatar
well then all you need is an installation kit (~$15) and a wireing harness (~$7). i have the same setup as you, except i have the tape player too. its an easy install
Old Apr 24, 2005 | 06:20 PM
nomad45's Avatar
sweet man, thanks for your help, i appreciate it.
Old Apr 24, 2005 | 06:23 PM
FatRyan's Avatar
no prob
Old May 22, 2005 | 04:57 AM
deliriousvisions's Avatar
deliriousvisions is an unknown quantity at this point
that bypass has nothign to do with the bose system or whatnot.......and if you open your door and you hear your door chime in the STEREO SPEAKERS then you need that part......otherwise your airbags will not deploy.......
(this is pasted from one of my other posts)
basically how taht works is, almost every GM, 2000+ has shared controls in the factory radio, it controls the airbags, and your door chime...... what they sold you "should" have been a GMRC01...that takes those controls outside the stock radio and into a little box......it has the regular metra 70-2003 harness on it, but the box has a pink wire that hooks into it, thats your digital wire for the airbag and door chime....the box also gives you a switched power source, for turning the unit on and off (red wire) so you dont have to tap into the ignition harness.
Old May 22, 2005 | 01:46 PM
FatRyan's Avatar
ORIGINAL: deliriousvisions
it is the Bose system that does that. With the bose system, the airbags are run through the HU (i dont know why). and if you dont get that adapter, they will malfunction. i didnt have the bose system (thank god), and i have no problems with my airbags.
SubbinBlazer
Apr 5, 2013 09:17 PM
Thrakhath
Nov 1, 2011 08:22 PM
Canadian88
Jan 27, 2006 05:20 PM
brad
Sep 2, 2005 01:47 PM
mharrison
Jul 23, 2005 06:42 PM
