CAp vs bigger alt?!?
Old May 16, 2007 | 01:41 PM
eshballa5's Avatar
eshballa5 is an unknown quantity at this point
Default RE: CAp vs bigger alt?!?
If not bench vise, then solder as well along with the bench vise for added insurance. My guess is the big 3 as well. But also like hillbilly said. Look at where your amp is grounded. Make sure the paint is all scratched away and the connection is good.
Old May 16, 2007 | 04:15 PM
bigbill23's Avatar
bigbill23 is an unknown quantity at this point
ok soon im doin the big 3 to my truck! im planning on doin a 10gauge wire or so. Terminals, would radio shack have those big terminals? i thought the battery grounded at the fuse block? where does it ground to the chassis at? what did u guys use for battery terminals with the bigger wire? and lastly...bigger power wire for my amp, where can i get a terminal small enough to connect to the amp?
Old May 16, 2007 | 05:02 PM
hillbillyinOhio's Avatar
First off, do not use 10 ga wire for your big three upgrade. will be a waste of time. Go with at least 4 ga or bigger. If you want to cheat, and if you have a battery with top and side mounts, you can get a 2 ga batt cable at any parts store.
Radio shack will have teminals that will fit, but i would suggest going to a local stereo shop and getting them.
The battery is grounded to the chassis right on the front clip. pull the batt out and you will see it. I always just run a new line down to the frame of the truck.
What is the actual model number of the amp? You can get wire gauge reducers to drop to a diff size.
Old May 16, 2007 | 05:46 PM
nick's Avatar
nick is an unknown quantity at this point
ORIGINAL: hillbillyinOhio
Bench Vise, hammer. Or you can just get theterminals that have set screws like these.
Clickyfor 1/0 ga
Clickyfor 4 ga
yea those style ofring terminals are sweet I dont use the stinger ones but they are the same thing if you find that you need to redo something all you have to do is unscrew them and then you can just reuse them I typicly wrap electrical tape around the base of the terminal and the wire for a little bit of added security
Old May 16, 2007 | 08:00 PM
bigbill23's Avatar
Ok 4 ga or bigger wire, approx 12 ft... My battery only has side mounts! And the alternator model # im unsure of, if its not stock then its acdelco replacement! where did you find a spot on the frame to ground the battery at? anywhere or was there a really easy localized spot?
Old May 16, 2007 | 08:28 PM
I awas asking for model of your Sony Amp, not the alternator. Just drop the wire down beside the engine and ground it on the frame there.
Old May 16, 2007 | 09:33 PM
Loud_01_Blazer's Avatar
Loud_01_Blazer is an unknown quantity at this point
if all you have is side mounts i would recomend getting these http://www.cardomain.com/item/STISLGMBATTthats what i had to use before i got my yellow top. i would do 1/0ga for your big 3, if you look at knu-koncptz you can get 1/0ga for like 2 bucks a foot.
MacArthur
Tires and Wheels
Jun 14, 2011 08:51 PM
ExplicitYourSelf
Dec 13, 2010 11:50 PM
boomtruck97
Dec 10, 2007 12:58 PM
jagblazer01
Aug 16, 2006 03:54 AM
2001blazer
Mar 13, 2006 09:25 PM
