Car Audio Discussion
Old Nov 12, 2010 | 05:10 PM
  #201
01vortec's Avatar
01vortec is an unknown quantity at this point
Originally Posted by blazinloud
link dosent work, but power dosent kill subs so dont worry
if you overpower a sub past it's thermal limits, yes, power will kill a sub.
RE SE's can handle 1000wrms if you keep the signal clean, I've ran over 700wrms to a single SR, and they're rated for 300wrms. I did this for over a year.
Old Nov 12, 2010 | 05:49 PM
  #202
69chevelle's Avatar
69chevelle is on a distinguished road
on a similar note, even underpowered you can toast a sub with a dirty signal.
back in my early highschool days I had a 150 rms JENSEN amp and roasted 3 alpine type s' 10's(individually of course, don't remember rms, but they were single voice 4 ohm) within a year... luckly the were replaced by A&B sound each time.
Old Nov 12, 2010 | 06:09 PM
  #203
01vortec's Avatar
You can blow any sub with a dirty signal.
You can also blow the sub by overpowering it and reaching the mechanical limits, not just thermal.
Old Nov 12, 2010 | 09:34 PM
  #204
ImScrewed92's Avatar
Right. Most subs give out from a "dirty" or clipped signal. But you can over power a sub and stress the componets to thier limits. Over excursion ripping the surround, heat inside the assembly killing the voice coils locking up the subs cone. I actually had a set of punch p1 15's (the older red and black subs) 150 rms and 300 peak IIRC. Ran on a cheap xplod 2000gtr (500x1 bridged). All of the sudden one sub locked up, hard as concrete. Then about 3 weeks later the other locked up. But that one was dirty signal not overpower for sure.
I will say though, when not bridged and when they were wired right and not getting a clipped signal those low end rockfords sounded pretty good. Took a beating for a good while also. Lookin foreward to seein Tyler's build with those p2's. Now that he's got some proof up and all . Interesting direction.
Old Nov 12, 2010 | 10:22 PM
  #205
69chevelle's Avatar
haha my best was a Phionex gold, don't remember the models, sub was ~500rms amp put out 600rms. got it professionally installed, seized the first hour of play. 2nd one lasted though
Old Nov 13, 2010 | 12:37 PM
  #206
MTopper's Avatar
my buddy locked up an old Polk MOMO 10. he powered it with a kenwood mono block. no idea what the sub rms was because nothing is on the sub, the amp was the kenwood KAC-8101D. the sub is in my garage and i can move it only when i put most of my weight on it...
great thread conversation
Old Nov 13, 2010 | 06:16 PM
  #207
blazinloud's Avatar
right, but its not the power that kills it, its the BUILD UP of heat from playing for extended periods. how do you think they burp 10, 000 watts on a single sub and have it come out perfectly fine? or wall socket them and be fine?
not to mention how often do you really intend on blasting the volume at a 50hz tone? cause music is dynamic and you seldom see what you believe to be full power from the amp. considering box rise imp. rise and everything else, i bet most people are only running half the power they think they're getting.
Old Nov 15, 2010 | 07:27 PM
  #208
MTopper's Avatar
so changing tides here.... talking with zedartwo in a different thread.... i love the cheap but "clean" power that MB Quart provides. i always wanted to play with their amps but never had the chance because i was either already happy with the amps i had or found a great deal when i had the money to afford them. anyone have problems with MB Quart or similar?
Old Nov 15, 2010 | 07:42 PM
  #209
zedartwo's Avatar
No problems but on a audio forum I was skimming through a Maxxsonics rep said MB quart WILL do over the rated power. my 1500 mono will to 1600RMS. That was good to hear for sure.
Old Nov 15, 2010 | 07:52 PM
  #210
jagblazer01's Avatar
lulz....I dont think MB Quart has made a good product since they were bought by Maxxsonics. I wouldnt believe all you hear until you see some actual clamped stats
