CB radio's Suggestions
Old 07-03-2010, 08:12 AM
wlorton's Avatar
Originally Posted by okvortec
Actually, I went to walmart and bought the cigarette lighter extension with a negative and positive wire and connected them directly to the cb wires.. plug and play! I can get a pic of the connection if you want.
And the CB doesnt stick out too far? The 29's look so much bigger... I didnt know where you could stuff em
  #22
Old 07-04-2010, 11:19 AM
m3ch's Avatar
m3ch is on a distinguished road
i just put mine down in the same area, but its a midland 1001z so, its small, and bassically can be put anywhere
  #23
Old 07-08-2010, 03:11 PM
CTYankee's Avatar
CTYankee is on a distinguished road
Received my Cobra 18WX ST II in the mail this morning and mounted the unit, but haven't run the power as of yet. Haven't received the antenna and will wait for that before powering everything up. But, this is where the radio went:
Passenger side under the glovebox with bracket mounted to the hard plastic part. Just enough width so it doesn't touch the sides. Also, glovebox only drops about 4" when open, so no interference there.
Will run the microphone cable a little neater when I hook-up the power, but clip is mounted just to the left of climate controls on that hard plastic under dash trim.
Radio dimesions are: 6 7/8d x 6 3/4w x 1 7/8h and there was plenty of leway if the 29s are bigger, other than the width, that was kinda cutting it close.
  #24
Old 08-10-2010, 07:29 PM
awesomeamerican1's Avatar
awesomeamerican1 is on a distinguished road
i was thinking about putting one there but i'm afraid of not being able to reach the **** to change the channels and volume n all
  #25
Old 08-10-2010, 11:29 PM
jdespain's Avatar
Best mounting location for my usage. Easily accessible while still being out of the way.
  #26
Old 08-10-2010, 11:47 PM
m3ch's Avatar
well reinstalled in a different place, UNDER THE RADIO works fine, i have it grounded to my door so i need to find a different place, and tune my antenna =( but eh, works good there
  #27
Old 08-16-2010, 10:01 PM
stlwaco's Avatar
stlwaco is on a distinguished road
I have a Cobra 29 LTD mounted on the roof. Looks good up there.
EDIT: I pulled down the front section of the headliner. I then screwed a metal commercial edger blade (1" self tapping screws) to the edge of the windshield frame (on the edge so the blade will extend out a little more). I then put the headliner back up then used 2" (see note at bottom) self tapping screws to attach the cb mount to the edger blade thru the headliner. Attached to cb, ran power, and connected my Little Wil.
NOTE: I used 2" self tapping screws to screw the mount on. Unfortunatly, I hit the actual roof. The lucky part is I didnt go thru the roof. Just put dimples on the outside. I am gonna take the 2" screws out and replace them with 1 1/2" screws then tap the dimples back down.
Best place to tap into the power and ground is at the stereo. Just get a couple line taps and hook it up. That is how I run my Cobra and have 0 problems with it.
Last edited by swartlkk; 08-16-2010 at 10:47 PM. Reason: *Consecutive Posts* - Please use the edit feature to add more information to your post if another member has yet to reply.
  #28
Old 08-16-2010, 11:04 PM
Kamelot314's Avatar
Kamelot314 is on a distinguished road
Right behind the center console!
  #29
Old 08-17-2010, 11:45 AM
Kamelot314's Avatar
by the way its a Cobra 18WX ST II
Boiler20
10-19-2013 03:53 PM
dan_t
11-25-2010 08:35 PM
iamchevyman5
11-07-2010 01:20 AM
black19
06-22-2006 03:35 PM
Quick Reply: CB radio's Suggestions
