Need HELP... Amp/battery power wire connector
So Ive done quite a bit of sound system hook ups in my life. The only thing it has always been on imports or cars that have a slip on terminal style connector on the battery. The type of battery that has a little post sticking out the top and you slide the ring on the post and tighten it using the nut. Anyways this is the first time I have seen this style of battery where you tighten the screw that goes through the terminal and into the battery.
Currently im in the the middle of my sound system install and I run into this. Im wondering if anyone has any suggestions on how to connect the amp power wire up to this type of battery.
I didn't do anything to the battery or the stock harness. I modified the terminal on power wire going to the amp and its all covered by a rubber terminal sleeve.
Now that I know there is a specific terminal connector like one shown above I will swap it out and do it up nice. Thanks xmradioguy...
JohnBarJB
Sep 28, 2020 07:34 PM
JRob238
Mar 20, 2011 04:46 PM
randallsblazen
Mar 9, 2009 10:45 PM
