Need HELP... Amp/battery power wire connector
Old Feb 15, 2010 | 03:00 PM
knightryderx2's Avatar
knightryderx2 is on a distinguished road
Exclamation Need HELP... Amp/battery power wire connector
So Ive done quite a bit of sound system hook ups in my life. The only thing it has always been on imports or cars that have a slip on terminal style connector on the battery. The type of battery that has a little post sticking out the top and you slide the ring on the post and tighten it using the nut. Anyways this is the first time I have seen this style of battery where you tighten the screw that goes through the terminal and into the battery.
Currently im in the the middle of my sound system install and I run into this. Im wondering if anyone has any suggestions on how to connect the amp power wire up to this type of battery.
Old Feb 15, 2010 | 04:30 PM
giod's Avatar
giod is an unknown quantity at this point
Umm... you just put the battery bolt through the ring terminal on your amp wire and screw it back in.
Old Feb 15, 2010 | 06:24 PM
well i got it. I just cut up the terminal i put on there, smashed down the crimp portion, and kind shoved it on there. thanks for the help.
Old Feb 15, 2010 | 08:39 PM
95Jimmy's Avatar
95Jimmy is on a distinguished road
Just to make things easier and since I needed a new battery anyway I just got a dual post battery. System's hooked up to the top terminals and hooked the stock ones back up to the sides.
Old Feb 20, 2010 | 12:43 PM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
In the future use a gm battery terminal bolt made for adding accessories
Old Feb 21, 2010 | 03:39 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
this sound slike a fire waiting to happen
Old Feb 21, 2010 | 05:58 PM
I didn't do anything to the battery or the stock harness. I modified the terminal on power wire going to the amp and its all covered by a rubber terminal sleeve.
Now that I know there is a specific terminal connector like one shown above I will swap it out and do it up nice. Thanks xmradioguy...
JohnBarJB
Sep 28, 2020 07:34 PM
Giselle Nani Koki
Jun 21, 2014 01:13 AM
JRob238
Mar 20, 2011 04:46 PM
randallsblazen
Mar 9, 2009 10:45 PM
sifko36
Sep 26, 2008 11:45 PM
