Stereo Wiring and Install Parts
Old Aug 9, 2011 | 05:09 PM
  #121
viper4559's Avatar
viper4559 is an unknown quantity at this point
Originally Posted by Blumerc
Also I looked at the first post to make sure I had it hooked up right but I have three extra wires that was not mentioned and i do not have onstar. there is a extra dark green, dark blue and a purple/white. do i need to attach anything to those?
I've been looking for the answer to this extra dark green and blue wire that no one seems to mention...does anyone know what they are for?
*** EDIT ***
I found at least part of the answer today. I've been slowly working on putting a new Alpine headunit in and I bought a module to retain my steering wheel controls. Well, I had to hookup that module to one of those wires tonight, so I'm assuming both are associated with steering controls somehow.
Old Aug 17, 2011 | 04:23 PM
  #122
zedartwo's Avatar
Check the fuse? I believe its in the dash panel.
Old Oct 12, 2011 | 01:57 AM
  #123
David Shelby's Avatar
David Shelby is on a distinguished road
I have a 2004 Blazer Extreme. I have installed a aftermarket radio in it before and had to buy the door ding...the part for that extra wire and chime cost me a 100 bucks...I have read that you can piggy back the the power wire from the fuse box or maybe the ignition hot wire. I have lost the part I purchased and there's gotta be a better way then spending a 100 bucks again...You seem to know your stuff can you help me out? Is the wiring harness I need 70-2003 (M)? Thank you
Old Oct 13, 2011 | 10:52 AM
  #124
zedartwo's Avatar
Believe me. $100 is nothing. The one that I HAVE to buy because my truck has onstar and truck phone. It costs $250.
Old Nov 4, 2011 | 08:19 PM
  #125
ozzman39's Avatar
ozzman39 is on a distinguished road
I Sorry if this has already been answered i have a 2003 blazer stock rds with a aftermarket HU.It has component speakers tweeters in the dash trying to find were the front door speakers meet the tweeters to tie them into a crossover and put aftermarket speakers in (want to use the wire that's already there)does anyone know were i can find this splicing location?
Old Dec 28, 2011 | 08:09 AM
  #126
carlspeed's Avatar
carlspeed is on a distinguished road
Hi all, I'm getting ready to install a stereo into a 2004 S10. I've heard that there is a module that I'm going to need for the truck to still work after I take out the factory head unit. I could see that if the truck had OnStar and the other normal useless crap, but this truck has freaking manual windows. Am I going to HAVE to have that stupid thing, or am I going to be ok if I just hard wire everything instead of using the wiring harness kit (which I've done numerous times).
Old Jan 10, 2012 | 07:53 PM
  #127
zedartwo's Avatar
Put the key in the ignition open the door and find out where the chime is coming from. If its from the speakers, you need the module. If not then you're probably alright.
Old Jan 11, 2012 | 12:06 AM
  #128
Defiant's Avatar
Defiant is on a distinguished road
Also check on the radio, if it says RDS on it, chances are you will need the harness. But if your truck is the base model chances are you aren't going to have it because I believe the RDS radio was optional and not standard equipment.
Old Feb 10, 2012 | 07:51 AM
  #129
Norm43920's Avatar
Norm43920 is on a distinguished road
Originally Posted by hillbillyinOhio
For 2002 up blazers the wiring is as follows:
Radio 12v orange+radio harness
Radio Ground black-radio harness
Radio Ignition dk. green+radio harness
Radio Illumination gray (dimmer)+radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- tan - gray+,- radio harness
RF Speaker +/- lt. green - dk. green+,- radio harness
LR Speaker +/- brown - yellow+,- radio harness
RR Speaker +/- dk. blue - lt. blue+,- radio harness
I have 03 Blazer
Im a little confused on 2 wires. Red and Yellow on the new stereo harness Red = Accessory , Connect to Ignition circuit or switched 12 volt source... Yellow = Memory, Connect to battery circuit or constant 12 volt source. I only see " Radio 12v orange+radio harness" In this post so Im wondering where the Memory wire hooks up. I believe in my old car I wired yellow and red together but the radio didn't shut off with the ignition and I dont really wanna do that.
Old Feb 12, 2012 | 12:11 PM
  #130
Norm43920's Avatar
Disregard my previous post. I found a wiring harness that would fit. had everything done in no time.
