stock cd player problems
Old Oct 30, 2010 | 10:33 PM
mov4x4's Avatar
mov4x4 is on a distinguished road
Question stock cd player problems
Well I'm having problems with my stock cd player. When I'm driving sitting in park or in neutral my factory cd player will shut off and turn back on real quick. I'm just trying to figure out if it is just a bad ground or something similar. Any answers would be appreciated.
Old Oct 30, 2010 | 11:08 PM
zerepdivad's Avatar
zerepdivad is on a distinguished road
get a meter and meter out what you're getting as far as voltage to the deck when it cuts out. if i recall right orange is constant 12v, yellow is switched 12v, and black is ground.
Old Oct 30, 2010 | 11:13 PM
mov4x4's Avatar
And I would just use it on the bare wires? And when it cuts out its for 1 or 2 seconds and then its back on
Old Oct 30, 2010 | 11:18 PM
zerepdivad's Avatar
you would either cut away a bit of the insulation and put the meters probes there or do waht i prefer and just backprobe the harness.
Old Oct 30, 2010 | 11:22 PM
mov4x4's Avatar
Ok ok I understand now. Thanks for the help
Old Oct 30, 2010 | 11:24 PM
zerepdivad's Avatar
yeah that's the simple way to see if for some reason one circuit either constant or switched is dropping in voltage. which would obviously cause the unit to shut off.
DVS Blazer
Jul 8, 2010 08:05 AM
01blazer
Dec 28, 2008 08:43 PM
Lilcheef
Feb 21, 2007 05:13 PM
supermancs
Jun 4, 2006 10:45 PM
Pugsley
Apr 21, 2006 09:02 PM
