Stock Radios that fit 98 Blazers
Old Nov 3, 2006 | 05:19 PM
TheJuicer's Avatar
TheJuicer is an unknown quantity at this point
Default Stock Radios that fit 98 Blazers
I was wondering if there was some resource that lists what other radios can fit into a 98 blazer. For example newer radios from newer trailblazers etc. I think I need to replace mine and would prefer a newer model if it will fit.
Thanks for you help!
Justin
Old Nov 3, 2006 | 06:52 PM
mikeywaynebygod's Avatar
mikeywaynebygod is an unknown quantity at this point
Default RE: Stock Radios that fit 98 Blazers
www.soniceletronix.com
should be all you need. just get an aftermarket head unit. then go to your friendly neighborhood wally world and pick out the dash kit, and wiring harness.
Old Nov 3, 2006 | 08:16 PM
ORIGINAL: mikeywaynebygod
www.sonicelectronix.com
Please edit your post to fix your link (as I have done in the quote above). You forgot the 'c' in eleCtronix... As the link is now, it sends you to a questionable automatically generated website. Also, please use the preview function and check your links before posting the message. You may be able to fix these mistakes before anyone else points them out to you.
Old Nov 5, 2006 | 10:09 AM
moleman's Avatar
moleman is an unknown quantity at this point
I'm sorry if it's a little late to reply to this, but you can get stock GM radios at replacementradios.com. Specifically, the Blazer ones are at http://replacementradios.com/index.p...a&filter_id=66
razorguy
Oct 19, 2015 12:49 PM
ohsofly
Jun 8, 2013 12:19 PM
03chevyblazze
Apr 7, 2013 03:44 PM
Spectreblazer
Feb 13, 2010 04:59 PM
93s15jimmy
Sep 20, 2006 12:46 AM
