Strapping 2 1000w amps
Old Nov 22, 2008 | 09:49 AM
SPLjimmy's Avatar
SPLjimmy is an unknown quantity at this point
Default RE: Strapping 2 1000w amps
thanks now i know where i could have looked to find that
Old Dec 1, 2008 | 01:58 AM
oakleyg's Avatar
oakleyg is an unknown quantity at this point
ORIGINAL: jagblazer01
ORIGINAL: bobditts
are you sure the amps are strapable? Not all amps are. they have to be specifically made to do that. Personally, I would just run one amp to each sub. 2000RMS is a bit on a stock charging system. I would definitely look into upgrading the alt.
x2 on this...its just as easy to run an amp to each sub. strapping can get complicated especially if both amps are not set exact. Bad things happen lol.
I think you got that backwards, gain matching the amps when you run one amp to one sub is a little more difficult than strapping them. When you strap them the slave amp gets all the settings from the master amp so theres less tuning involved.
Old Dec 1, 2008 | 11:33 AM
jagblazer01's Avatar
ORIGINAL: oakleyg
ORIGINAL: bobditts
you are correct lol.....my bad hahaha...it obviously was one of those days lol
Old Dec 7, 2008 | 01:15 AM
PABlazer's Avatar
PABlazer is an unknown quantity at this point
i have 2 diamond audio tdx subs with 2 diamond d51200.1 ampsrunning along with a high amp... each 1200 is runninga sub... putting an extra battery in the back is a bad idea cuz that strains ur alt even more... when every1 says strap them that can b good and bad at the same time... ifu mess up onsomthin bye bye subs... if i were u i would just run each amp to each sub and bridgethem down as low as u possiably can... also run 1/0 gauge if u can afford it...u will notice alot of difference if u do that...
Old Dec 7, 2008 | 09:48 AM
bobditts's Avatar
bobditts is an unknown quantity at this point
ORIGINAL: PABlazer
either the amp is bridged or its not, there are no choices
Old Dec 7, 2008 | 05:06 PM
PABlazer's Avatar
ORIGINAL: bobditts
ORIGINAL: PABlazer
i was talking about the subs bringing them down as low as u can
Old Dec 7, 2008 | 11:48 PM
bobditts's Avatar
thats not bridging. you are talking about wiring parallel or series to obtain the desired impedence.
Old Dec 28, 2008 | 02:35 AM
blazerbumpin's Avatar
blazerbumpin is an unknown quantity at this point
yeah its called strapping
Old Dec 28, 2008 | 12:23 PM
bobditts's Avatar
ORIGINAL: blazerbumpin
post ***** much?
Old Dec 28, 2008 | 06:25 PM
ORIGINAL: bobditts
post ***** much?
You do not have to worry about this tool again. blazerbumpin == tussy14. Both have been banned.
ExplicitYourSelf
Dec 13, 2010 11:50 PM
thrash902
Jan 28, 2010 06:58 PM
XBlazer01
Jul 14, 2006 08:29 PM
blazinloud
Mar 23, 2006 05:54 AM
FarkDaNarc
Dec 4, 2005 10:10 AM
