Tech Guru's
Old 12-08-2007, 08:34 PM
hillbillyinOhio's Avatar
Default RE: Tech Guru's
try this and let me know what happens to the LED
Press and hold in the programming button you found. Turn ignition on and back off (while holding button in) Release the button and press and release it once more. then peep your led. what is it doing???
Old 12-09-2007, 07:59 AM
drperry's Avatar
I had the 791XV on my old Lumina...
Watch out for randomly un-programming remotes, lol.
At least if you've got the older, white remote...
Old 12-09-2007, 09:08 AM
JediKnight2's Avatar
JediKnight2 is an unknown quantity at this point
I couldn't get the programming to work on a 97 Jimmy....I tried both turning the key from off CCW towards me and CW away from me twice....
Old 12-09-2007, 10:05 AM
Dabber's Avatar
Dabber is an unknown quantity at this point
Hillbilly, When I did that the led flashed 6 times and kept repeating that until I started the truck when I shutthe truck off and armed the system it was still flashing 4 times.
DrPerry, I don't have a white remote I have the blue one with display and four buttons.
Old 12-09-2007, 08:31 PM
i think you have some things going unprogrammed. 4 flashes means the shock sensor and 6 means you have a loose wire in a 6 pin harness. the wire is the hoodpin switch.
Old 12-09-2007, 09:04 PM
Dabber's Avatar
I believe my shock sensor isn't working( hasn't for a while now) Just never flashed any more than normal. As for the 6 flashes being a loose wire, Why would it come up now. I tried the hood pin and it works just fine.
Old 12-09-2007, 09:15 PM
not sure. but how did you test the hood pin??? I think the unit is just going bad. those things shouldnt be popping up like that now.
Old 12-10-2007, 09:03 PM
Dabber's Avatar
I had the hood open and I held down the hoodpin then remote started the truck and let go of the pin and it shut off. Same to check the alarm let go of the pin and the alarm went off. What unit would you be speaking of?? I can't understand why they would pop up noew either since I had no problems till I did this. But man Does it ever feel good to not be locked in my truck anymore!!!!!
Old 12-10-2007, 09:22 PM
i think its your vipers way of saying it doesnt want to play anymore.
Old 12-12-2007, 04:43 PM
Dabber's Avatar
It would be just my luck Too!!!!!!
jackdough
08-08-2010 12:37 PM
mrshaneb
31
07-03-2010 01:16 PM
spud-truck
12-18-2009 11:29 AM
arctic4wd
04-06-2008 07:24 PM
rtz28
20
12-21-2006 04:30 AM
Quick Reply: Tech Guru's
