1999 4x4 blazer 4dr rebuild
Old Apr 17, 2012 | 09:04 AM
dano440's Avatar
dano440 is on a distinguished road
Default 1999 4x4 blazer 4dr rebuild
Replaced transmission (automatic)
Replace left side drive axle
Replace left side front bearing
Replaced vacuum lines
Replaced front drive shaft
Replace front dif left side seal
Replaced fuel filter
Replaced door pin bushing
Changed fluid in transfer case
Replaced damage rear def fill plug
Replaced water pump
Replace shocks
Replace brakes
Re-balanced tires
Replace idler arm
Replace right front wheel bearing
Replace right front axle
Re-tighten shocks
Installed keyless entry
Replace timing cover seal
Replace serpentine main belt
Replaced idler pulley
Replaced belt tensioner
Tested fuel pump pressure
Replaced radiator
Replaced radiator hoses
Replaced lower ball joints
Replaced left upper ball joint
Replaced dist. Cap & rotor and wires and plugs
Replaced heater core
Replace heater hoses
Replaced rear tires
Replaced fuel pump for the second time (Delphi this time not Airtex)
Replaced fuel filter with new fuel pump
Installed an Add-A-leaf kit to rear springs
Things left to do.
Transfer case tail shaft seal
Fix exhaust leak on left side
Replace front tires
Replace oil in rear end
Replace or fix passenger side recline lever
Reinstall driver’s side door spring
Install steering stabilizer
Old Apr 17, 2012 | 09:14 AM
dano440's Avatar
Replaced windshield last year (lawn mower + rock!!! bad day)
Cleaned MAF Sensor
Replaced Air filter
basically trying to get everything back up to standard that got neglected over the last 8 years of ownership (while the wife drove it)
other things not sure what to do about.
driver sided seat-belt retracter is really slow.
drive ability issue under moderate acceleration up hill there is a breif point of rough acceleration or cutting out but you can push on through it or let up on it and it goes away (possible TPS sensor?, or MAP Senors no codes, no CEL light)
also have the morning loud ticking lifter that quiets down after it warms up, but still tick all the time.
Old Apr 17, 2012 | 09:18 AM
dano440's Avatar
another issue under heavy acceleration I have Cam rattle or pinging.
Old Apr 17, 2012 | 09:22 AM
dano440's Avatar
I also seen the tread about the hose for the secondary air pump that just sticks out in the engine compartment.
Is there a cheaper way to fix it other the GM's $50 hose kit??
Old May 8, 2012 | 07:39 AM
dano440's Avatar
replace rear transfer case seal, leveled center drag link, re-tighten exhaust flange, replace all four tire (235 75 R15) removed & clean throttle body. repaired driver's side door speaker blazerleft.jpg
Old May 10, 2012 | 10:03 PM
dano440's Avatar
replace that last ball joint now all have been replace, now of to the alignment shop tomorrow, plus after the 5th tightening the exhaust leak is gone!!!!
the project is almost done. just a few more things left on the list
Old May 11, 2012 | 12:44 PM
dano440's Avatar
out of the alignment shop, pretty much everything was out of spec. toe-in by quite a bit.
Old May 11, 2012 | 08:59 PM
Brian_D's Avatar
jeez, it should be about brand new now
Old May 11, 2012 | 10:56 PM
4x4blazerguy's Avatar
That is exactly what I thought. I think I would of taken a vacation to Brazil & bought a new one & wouldn't of spent much more.
Old May 12, 2012 | 07:22 AM
dano440's Avatar
well in this county they tax us to death on property tax, the taxes on the 99 are $135 a year. as long as I can keep it running the better off I am our 2006 is $425 a year. and the old beast only has 3 little dings in it, otherwise it's perfect, interior is almost perfect, and now everything works except the recline lever, 3rd brake light, and driver's side door spring. it runs and drive like a new one almost. I have most of the squeaks and rattles out. Wednesday I checked the mileage and it getting 19 to 20 mpg. NADA says it worth $2950 I bet I can drive that much out of it in the next 3-4 years. insurance is only $48 a month, its 13 years old and only has 133,000, I use it for shooting matches, fishing, and hunting.
I can't buy any thing out on the open market to replace it under $5000 around here. example 2005 trail blazer 99,000 miles 4x4 $10,999 and it rougher than mine is, and it 6 years old. and it get worst mileage than the one I got. plus mine is paid for and the insurance on 2005 it $140 per month the 99 is $55 per month
bryanbc
Engine & Internal
Jan 22, 2013 01:51 PM
DreezyBeezy
Jun 30, 2012 06:39 PM
NowhereMan1966
Jun 19, 2012 10:31 PM
DA B BLAZER
Apr 18, 2010 04:56 PM
gtmci84s
Oct 29, 2008 02:29 AM
