So I got back brakes to do(going by sound atm as I havent jacked up the truck and checked). But I got a screech, the odd thing with it, is that it's not consistent with the warning bracket. Comes and goes mostly with speed, 90% of the time it happens at 50 km/h and after, sometimes itll go away if I hit a bump.
then it made me think... what does an axle gear sound like when theres no or almost no oil in it?
do u have the 4 button case I had a metal on metal noise turned out my replacement cv joint slid on too far and was rubbing
I got the 3 button. I'm planning on jacking the truck up this weekend during free time, and check brakes, u joints, fluid levels and such.
my problem now, my test port pisces fuel any time the lid is off... and driving it makes enough pressure to seep out from under the cap. So my mileage is cut by half...
any one know if it's just a regular air valve like in a tire stem? I got that special tool and I'll just tighten it... could be where my lack of power is coming from too....
Found my squealing lol... my passenger rear caliper is seized. So I'm pulling the new ones off the donor axle (po replaced them shortly before selling the truck), and going to swap them both out as the drivers side looks new still...
also took some measurements... original axle sits at 53 1/4" outer rotor to outer rotor. Zr2 axle sits at 57 1/4". I'll be very happy with that when it gets swapped in.
With those measurements I think my tires would stick out quite abit if I managed to find a zr2 axle I’m running 1.25” spacers and it’s nice but with a 2” and my -16 rims fell it might be abit much
