The Branch Blazer - 99 Blazer Build
Old Oct 27, 2016 | 06:21 PM
  #81
Red9Beard4's Avatar
Red9Beard4 is on a distinguished road
Interesting to see how this pans out. Been thinking about SAS my 97 next year when I get another daily. Nice work so far!
Old Nov 21, 2016 | 07:59 PM
  #82
ZachC540's Avatar
ZachC540 is on a distinguished road
Originally Posted by awesomeamerican1
You should have gotten an earlier u-joint style tcase so you don't have to deal with slip yokes. What was the reason you went with a dana 50 instead of that 60 you had?
I'm gonna swap in a Cherokee front output shaft and do a SYE kit on the rear so it has fixed yokes. And I got rid of that 60 because of the center-axle-disconnect being too much of a pain to work around. The 50 having a single piece axle and smooth tube makes it easier to modify. Also the Dodge 60 is low pinion and the 50 is high so that makes for better drive shaft angle and ground clearance.
Old Nov 21, 2016 | 08:15 PM
  #83
ZachC540's Avatar
Default 6 months later...
Finally picked up the rear end last week! Got a 9" out of an '81 F150.
Old Nov 22, 2016 | 08:55 AM
  #84
Jamaroon's Avatar
what are you doing for bolt patterns? converting the front?
Old Nov 24, 2016 | 07:30 AM
  #85
ZachC540's Avatar
Yeah, I'm gonna go with spacer/adapters even though I'm a bit weary of ball joint wear. But I'm gonna have to narrow the front housing a good bit to make it fit and the spacers will bring it back out to about the same width as the rear. Plus that'll move the wheels out from the springs a little bit too
Old Nov 26, 2016 | 10:12 AM
  #86
ZachC540's Avatar
After doing some research, I will not be going with spacer/adapters. The only ones I could find are about $170 for each side and questionable as far as strength is concerned. So I'll just have to drill holes like you did, Jamaroon.
Old Nov 26, 2016 | 01:44 PM
  #87
ZachC540's Avatar
Went and picked up some 52" Chevy 1/2 ton springs for the front today. Gonna have to tear the pack apart because someone made a weird bastard pack and threw a short spring right in the middle.
Blaze1Chef
Mar 7, 2021 10:44 AM
JS_blazer
Mar 21, 2010 07:17 PM
SFRANZ3
Lifting Tech
Jan 13, 2008 01:11 AM
91 Streeter
Jan 26, 2007 11:10 PM
