KM346's SFA blazer (lots of pics)
Old May 6, 2013 | 05:26 PM
  #91
KM346's Avatar
KM346 will become famous soon enough
Originally Posted by Bubba84
how much was that wheel ? And was it a PITA to install? Being that there's a air bag in our Jimmy's lol
I forget what i paid for it... I pulled it out of the junkyard last year and have been meaning to swap it in for a while. Install is easy, it only takes like 10 minutes. Just need to pull the battery / SIR fuse, unclip the airbag from the back of the wheel, disconnect the connection and use a wheel puller to pull off the wheel.
Old May 7, 2013 | 01:06 AM
  #92
Diaita's Avatar
Originally Posted by KM346
I don't even notice it anymore. Ill pull it apart one of these days.
...either that or take it to the dealer and tell them it turned on driving down the highway one day and i can't get it to shut off no matter what i do.
I tried the dealer option, they wouldn't look at it since I modified the brakes. A resistor, or black tape it is...
Old May 7, 2013 | 06:08 PM
  #93
KM346's Avatar
Oh... i was only kidding about going to the dealer. lol
Check out post 161 here...
03 stepside build - Page 4 - S-10 Forum
probably the route ill take when i eventually do it.
Old May 7, 2013 | 06:14 PM
  #94
KM346's Avatar
After work today i started tearing into my other t-case...
I bent up the rear output bearing snap ring so i ordered a new one from the dealer today... other than that im also waiting on a range/ mode shift fork pad kit i ordered for it, then its going back together and going in the truck! ... again.
Attached Thumbnails KM346's SFA blazer (lots of pics)-photobucket-27503-1367967001584_zpsb33e7e0b.jpg   KM346's SFA blazer (lots of pics)-photobucket-68136-1367967128939_zpsdda3a8b9.jpg   KM346's SFA blazer (lots of pics)-photobucket-47454-1367967054118_zps8fbb8fe5.jpg
Old May 7, 2013 | 07:11 PM
  #95
Diaita's Avatar
That mod won't work on my '96, I don't think. I pulled the bulb(not LED on mine) and it turns the Brake light on if the ABS light is missing or burned out.
Old May 7, 2013 | 08:07 PM
  #96
KM346's Avatar
Oh whoops i forgot yours is a 96 ... Have you tried just unplugging the big plug by the air filter on the abs module?
thats what i did on my 97 to get rid of the light.
Old May 9, 2013 | 11:47 AM
  #97
Diaita's Avatar
The ABS module is unplugged, sitting on the shelf in the shop. The trucks ECU sets the ABS light because the module isn't there, and sets the BRAKE light if it has a fault with the ABS bulb. Truck's too smart for it's own good...
Old May 9, 2013 | 01:17 PM
  #98
abig84's Avatar
take your truck off roading a few times with the window down, the mud will cover it up. i dont see mine anymore
Old May 9, 2013 | 01:27 PM
  #99
KM346's Avatar
Hmm I had just the large connector unplugged on my 97 with everything else still plugged in and didnt have either of the front abs sensors hooked up and got no lights. Maybe if completely unplugged / removed it sets the light off...
lol!
Old May 19, 2013 | 11:44 AM
  #100
KM346's Avatar
After making an insane low ball offer through email on CL my solid axle obsession has gotten the best of me today (again)... I picked up a D44 front axle out of a 86 Jeep Grand Wagoneer. No immediate plans for it, but eventually it will end up under a truck i own lol.
here's a pic:
^That SOB is a lot heavier than a d30. Loading it just about broke my back at the guys house. what a PITA... but it will be worth it.
Im still not sure which rear axle I'm going to pair it with... i could find an Isuzu Rodeo rear D44 that's the same bolt pattern... swap Ford 5 lug outers onto it and run the Ford 9" i have in pieces in my garage. OR swap 8 lug outers and run a Cab and Chassis 14 Bolt ff... decisions decisions
Other then that no real updates... been super busy with work which is why the t-case is still apart. I decided to go nuts and replace all bearings / seals etc. so im still waiting on parts for that anyways.
Attached Thumbnails KM346's SFA blazer (lots of pics)-photobucket-80587-1368919359619_zps66c65c0b.jpg
