My small 96 Blazer build
Old Jun 4, 2013 | 04:12 PM
  #521
richphotos's Avatar
awesome on the shift
and even better on not having to unbolt any of that. everything is coming up milhouse
Everything's Coming Up Milhouse!
Old Jun 5, 2013 | 09:21 AM
  #522
El_Beautor's Avatar
The shift controller is an electronic shift kit it has two stages of firmness on the shifts. I didn't have to do anything with the steering shaft it just extended itself as I jacked. I do have a bit of binding in the steering now but you should be fine since your going back to stock height.
Rex, it's interesting that you have some binding in your steering. I haven't had any problems with mine. Have you considered following the instructions for the ZR2's from the installation manual to drop the steering column 1/4"-1/2" by ovaling the bolt holes slightly?
Old Jun 5, 2013 | 09:40 AM
  #523
rexmburns's Avatar
Super Moderator
Yeah I actually plan to do that! I just need to buy or borrow a dremel to make the job a little easier
Old Jun 11, 2013 | 02:26 PM
  #524
rexmburns's Avatar
Super Moderator
Well I got my DR44G alt from FedEx today so I figured I'd go ahead and throw it on Bought it off a member on s10forum for $50. Not bad I don't think since I didn't have to search the yard for it or anything.
DR on the left
You can kinda see where my other alt looks burnt I dunno what that's all about but it could have something to do with why it sucked so bad lol
Went to Advance and picked up a little longer belt.
All is good to go! Now when I come to a stop my volts stay right at 14 and don't drop to 9-10. I can have the AC on high, high beams on, and the efans on hi and it still stays at 14 volts. I should have done this a long time ago!
Attached Thumbnails My small 96 Blazer build-ebe060df-3446-4070-a52f-e046717bc617-2984-0000039a9791f1f0_zps95210fea.jpg   My small 96 Blazer build-90760189-da40-465c-9d75-bcb46060c57c-2984-0000039a8b6ac349_zps0c47ce62.jpg   My small 96 Blazer build-cd03efb0-7d69-49ee-b573-95c3711a6ac6-2984-0000039a85a3f3ea_zpsec5b708b.jpg   My small 96 Blazer build-9be333da-8d6f-45d9-9269-d6946482bd3b-2984-0000039a7f669204_zpsd1b9b383.jpg
Old Jun 11, 2013 | 08:40 PM
  #525
okiedoak20's Avatar
holy smoke that alt. made that big of a differance.... so Rex your showing 14volts no matter what gets turned on...
Old Jun 11, 2013 | 10:09 PM
  #526
rexmburns's Avatar
Super Moderator
Yeah I was running high beams, ac on high, both Efans on hi, my wimpy radio was on, and I had a buddy put it in gear and hold the brake and still read 14v
Old Jun 12, 2013 | 06:38 AM
  #527
Tajohns34's Avatar
I am doing mine, probably this weekend. I have to convert it to a 4pin, but I will write that up too. When my e-fans turn on high I drop to about 12v, I also have the intrepid fans. I also got at smaller alternator pulley.
Old Jun 12, 2013 | 06:51 AM
  #528
rexmburns's Avatar
Super Moderator
Where'd you get your pulley from? I was thinking about doing that as well.
Old Jun 12, 2013 | 03:34 PM
  #529
bryanbc's Avatar
bryanbc is on a distinguished road
What was the part number for the belt you got?
Old Jun 12, 2013 | 03:38 PM
  #530
rexmburns's Avatar
Super Moderator
It is a "Drive Rite" 970K6. I don't like it and I am going to use it to cross reference and get a gatorback but just haven't had the time yet
I also just finished my Corvette servo install. I will do a write up tomorrow when I have more time to do it right!
