Project Sleeper Blazer
Old 10-09-2017, 07:58 PM
Tajohns34's Avatar
It sounds really good.
  #52
Old 10-09-2017, 09:39 PM
ChuckNTruck's Avatar
Thanks!
i need to get the tune dialed in a bit more because im very rich on the top end. I think once i get it dialed in ill jump my shift points a little bit higher to around 6000-6200rpms.
I really should put it on a dyno and see where my power curve is because this thing wants to keep pulling through the rpms.
  #53
Old 10-19-2017, 10:08 PM
calereeves's Avatar
calereeves is on a distinguished road
Nice work! I've got a ton more room in my k5, but I'm considering swapping a spare 5.3 for the 350 that's already in it. Love that you kept a/c
  #54
Old 12-06-2017, 12:33 PM
marty68's Avatar
marty68 is on a distinguished road
revive an old thread ... I am curious. does the blazer trans work with the 5.3? same wiring same plug?
  #55
Old 12-06-2017, 12:37 PM
marty68's Avatar
disregard lat post. I now see original trans was a 5spd.
  #56
Old 02-18-2018, 10:48 AM
BossToneKC's Avatar
BossToneKC is on a distinguished road
Originally Posted by ChuckNTruck
Thanks!
Hey! I’m new to the forum and I have a 2003 Blazer. Best thread I’ve seen on a swap so far!! Wanting to do the same build but curious about the budget 🤔. My 4.3 been leaking coolant it seems like from everywhere so it’s time for a update.
  #57
Old 02-18-2018, 06:51 PM
Originally Posted by BossToneKC
Hey! I’m new to the forum and I have a 2003 Blazer. Best thread I’ve seen on a swap so far!! Wanting to do the same build but curious about the budget ��. My 4.3 been leaking coolant it seems like from everywhere so it’s time for a update.
Nice blazer, i love that color!
The swap itself cost me about 6k including the engine and transmission. The cam swap alone cost me about $800-$1k because i upgraded the cam, lifters, push rods and valve springs while i had it apart.
Im about 9-10K into my build now including the $1200 i paid for the blazer itself, the Detroit Truetrac limited slip diff and i also replaced all bushing and bearings in the entire suspension and drive train with the exception of the pinion bearings.
The last thing i need to do is have a trans built properly and a higher stall converter. It runs good right now but the current converter is way to tight for the cam.
  #58
Old 03-15-2018, 10:01 PM
Finally got tired of the lazy shifting stock 4L60E so i had one built along with a FTI 3200 stall Billet converter. Got the bell housing and tail shaft swapped from a spare trans i had laying around but i kinda wish i would have painted them to match the trans case. Oh well, Hopefully I will get it swapped tomorrow.
  #59
Old 03-20-2018, 11:29 PM
twiggss's Avatar
twiggss is on a distinguished road
Nice build!
I've read on some swaps that mods have to be done to the A/C box. Looks like you were able to avoid that?
  #60
Old 03-21-2018, 10:39 AM
Originally Posted by twiggss
Nice build!
I did not have to modify the A/C box at all.
But i highly suggest removing it when installing the engine because i did crack mine by accidentally bumping it.
Quick Reply: Project Sleeper Blazer
